Part numbers for Pistons/rings for CAEB?
While I can live with a quart of oil every 300 miles, its less than ideal for the car I'm sure... (i tested compression at 130 in each cylinder for what its worth)
So I've decided I am going to crack it open and change the rings (and pistons, I assume) myself. While I am there do the chains/tensioners and poke around at anything else
Question is, what are the right part numbers for the pistons and rings, and where can I get them?
Audi OEM (from Audi) are $400+ for pistons and rings per cyclinder when I looked.
Is there other options? Also, if I do source OEM, do I then need new connecting rods (bigger wrist pin)?
Are there options from other sources?
If i found a use engine block with pistons and rings from a 2012+ would I be able to use my current head, and is that new enough to resolve the wear?
it is at 120k miles I should add...
... I've tried AoA, supplying dealer, other dealers... i bought at 83k miles from an Audi dealer and they weren't interested in helping me out beyond Stage 1
I am not familiar with what needs to be done for the oil consumption fix, but here is a start.
https://www.ecstuning.com/Audi-B8_A4...nical/Pistons/
You may do some Googling for a guidance.
I have a 2012 that had the oil consumption issue, so I would not buy that engine block. Thankfully in my case everything was covered by AoA.
pilot345
12v V6 Discussion
06-30-2005 03:49 PM
magurochan
10-08-2001 06:21 PM
