Test Forum B5 FAQ
A couple of questions...
Old 02-21-2000, 12:10 PM
Just Plain Cliff's Avatar
Default A couple of questions...
What about access from 2 different computers...as in "at home" and "at work"? Can you have two different email addresses maintained under one login identity, depending upon which machine you login from (or enter the forum from, if you don't logout)?
Old 02-21-2000, 12:12 PM
Member
Johannes Erdfelt's Avatar
Default There's a couple of things you can do
You can login from 2 different machines and it'll work fine. I've done that at home and work (I'm at work right now). It sends the same cookie to both accounts.
Or if you want, you can create 2 different accounts. I wouldn't suggest that route tho. But if you really want to... Remember, 2 different accounts can't have the same name (or email address)
Old 02-21-2000, 12:20 PM
Default Re: There's a couple of things you can do
Format is absolutely great...very readable. But if I am reading you correctly, I can't have two accounts with same name... but with different email addresses? If that's so, I just established this account with my work email address, but would rather have one using my current login, but with my home email address. So is there some provision for deleting an account and re-opening a new one (using the same login)? Am I being clear enuf?
Old 02-21-2000, 12:31 PM
Member
Default Umm, I think understand
When you create an account, it checks both the name and email address to see if it's a duplicate. So, no 2 accounts have the same name or same email address.
If you <a href="mailto:jerdfelt@audiworld.com">email me</a> then I can manually update your account with your home email address.
Old 02-21-2000, 12:42 PM
Email sent...and thanks!
Old 02-21-2000, 04:16 PM
Cliff Melick
Guest
Posts: n/a
Default Test post
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Old 02-21-2000, 04:20 PM
Cliff Melick
Guest
Posts: n/a
Default Re: Test post
<center><img src="http://131.107.68.28/AudiWorldPics/2000/cfmtt05.jpg"></center><p>
Old 02-21-2000, 04:25 PM
Cliff Melick
Guest
Posts: n/a
<img src="http://131.107.68.28./AudiWorldPics/1999/cfmtt01.jpg">
Contrast between aviator gray and lake silver metallic TTs in partial shadow
Old 02-21-2000, 04:29 PM
Cliff Melick
Guest
Posts: n/a
This stuff is an absolute <i><b>GASSS!</b></i>
Old 02-21-2000, 04:41 PM
Cliff Melick
Guest
Posts: n/a
Default Last Test Post
<img src="http://131.107.68.28/AudiWorldPics/1999/cfmtt03.jpg">
<B>A gaggle of TTs</B>
<img src="http://131.107.68.28/AudiWorldPics/1999/cfmtt04.jpg">
<B>A gaggle of S4s</B>
Quick Reply: A couple of questions...
