Battery Drain Help
Battery Drain Help
Ok so here goes nothing. I have been chasing down a battery drain on my 2001 Audi TT. So far I have found 3. One from the alternator. One coming from the fuseable link that powers the cooling fans & control module. And one I have traced back to the relays under the dash. i have pulled all fuses in fuse box. Disconnected the comfort control module in the truck. With a multimeter attached between the fuse on top of the battery that powers the interior relays and it reads almost 12v. so then i pulled a fuse which from all i can figure is some sort of thermal fuse its green and silver located under the dash, and the power drops to zero. so my question is what does this fuse send power to. I have looked everywhere on the net trying to find out what it powers and have had no luck. The fuse in question in the picture is very bottom right silver and green one.
Also to maybe help with my problems. this is a list of everything that is not working on car
ac
central locking button
dome lights work only sometimes
key fob
heater doesnt get real hot just warm
ac
key fob
Leave everything connected after charging the battery/driving the car. Park car in the cold, shut off and lock. After six hours open the hood and put your hand on the alternator. If it isn't stone cold but instead toasty warm; One of the diodes in it is leaky. Replace all of the diodes or the alternator itself.
If the alternator is cold, continue using standard automotive electrical system troubleshooting techniques.
tt0324
11-06-2008 06:11 AM
ErikS4
07-07-2007 05:28 PM
