Fuel System Failure and blown fuse #37
Hello, I'm new to this forum thing and hoping someone can help me. My 02 TT Quattro won't move fuel. I replaced relay and fuse #28 (fuel pump) is fine. So I set out to replace the fuel pump. Once I got to the pump I test lighted it to make sure I had voltage to the pump, none detected. After a bit more research I discovered the fuse #37 (engine timing: petrol) was blown. Each time I replace it, it blows when ignition key is turned on (unless I remove relay before turning on ignition).
Some more back ground. I have owned the car for 9 months. I put all new coil packs and plugs in 6 months ago. Runs so much better. Recently a new battery. Has been a great daily driver until it stalled at a stop light last week and has not recovered.
Im completely stuck at this point. Any help you can be is greatly appreciated.
Thanks, Bosie
Thanks, Bosie
Standard automotive electrical troubleshooting techniques apply. So, disconnect fuel pump from vehicle wiring harness. Does fuse still blow?
No; Replace fuel pump or something past what you disconnected.
Yes; Reconnect pump and disconnect the wiring harness at the next connection point.
Continue until the fuse no longer blows.
You will need a vehicle wiring diagram (read: proper service manual) and a good multimeter ( The free/$7.00 Harbor Freight ones are junk) along with some basic knowledge.
Thank you Mister Bally for the good advice. That was the first thing I did was to disconnect fuel pump when I saw fuse was blown. It blew again with it disconnected. I did start to trace but didn't finish as you suggested because I had this nagging realization that its not the fuel pump fuse that is blowing out.
I think your advice to get a good manual is good, then I maybe able to determine what fuse #37 actually protects. Not sure which manual is a good one for Audi though
Also thanks for the advice on Harbor Freight. I have a Gardner Bender meter. Not much better but gets me there.
Well it's been awhile since I worked on this Audi and made a post. I determined that fuse #37 is directly connected to the ECU power supply relay. I now have a new relay and fuse #37 is not blowing. The car still does not start. I have determined the following: the timing belt is good, the car does not have spark and it is not getting fuel. It only turns over. The code I am getting at the moment is P0685. This code reports "ECU Power Supply Relay open" not sure why I am still getting this failure when I have a new relay.
Any ideas.
Thanks
Any ideas.
Thanks
Any ideas.
Thanks
Any ideas.
Thanks
