How low can you go for 1999-2002 TT Mileage
Old 02-20-2012, 10:37 AM
Steve_TT_Ottawa's Avatar
Default How low can you go for 1999-2002 TT Mileage
My 2001 225HP Lake Silver Hardtop has 11,000 kilometres. It's driven only when I find the time. Any out there with less mileage?
Old 02-21-2012, 04:44 PM
lewes2's Avatar
Hey Steve, curious to know if you have changed your timing belt and water pump yet, given the passage of years? The 2001 TT I am taking delivery of this week has but 32k miles.
Chuck
Old 02-26-2012, 03:34 AM
nilreb's Avatar
wow! 11,000 miles. I don't think he's changed tires or engine oil either.
Old 02-26-2012, 07:14 AM
xradman's Avatar
He says 11,000 kilometers which would be 6,835 miles. I always wondered what kind of maintenance you would do for cars with such low miles. Do you change oil annually even though it only has 500 miles on it? What about belts, brake fluid, coolant?
Old 02-26-2012, 02:07 PM
AudiMick's Avatar
Not to mention the tires, which are probably hard as rocks by now.
10-15 miles a week, not sure that's a good thing. Cars need to be driven.
Old 02-27-2012, 03:11 AM
I have changed oil three times and I have original tires. Yes they are getting hard. Hmmm had not thought of that. Nothing else has been touched. Any suggestions???
Old 02-27-2012, 06:43 AM
AudiMick's Avatar
Depends on how it gets driven, I would be more concerned about 1-2 miles a day than 30 miles every other weekend.
If it's a weekend toy, replace the brake fluid of course as it will be pretty much useless by now. I would change the engine oil and filter once a year, synthetic oil good quality filter. Drain and fill the Haldex. The Hungarian rubber parts tend to shrivel up on these cars, check the shock upper mounts and the suspension in general, also the engine + transmission mounts .
The big thing is the timing belt, can't advise you there. Maybe have it checked. The belt will be dried up and the tensioner is probably questionable.Water pump might be OK although it probably has a plastic impeller which in the early days wasn't very durable. Drain and fill the cooling system maybe.
Old 02-27-2012, 09:00 AM
Interesting issue with the tires. I've not changes them but they do seem to be getting harder. Maybe I should change them? Hmmm I've changed oil three times and not changed other fluids. But I suppose this spring I'll change these. Nothing else has ever been done. It's seen rain once. The day I drove it home it was raining. My only problem has been that once in a while the tach shows zero, but after about 20 minutes or so, it starts to work it I turn motor on and off. I certainly hope this is not the dash issue cropping up which I have started to read about. The car has been vacuumed once.
Old 02-27-2012, 12:09 PM
The tires are getting hard so maybe I should change them. Oil has been changed 4 times. No other fluids changed yet but I'll do that. I'm starting to notice Tach sticks at zero for 10 mins until it gets warm. Wonder why that is. Car has been vacuumed once! Never needs it. Seen rain once. Never snow. Any suggestions??
Old 02-27-2012, 12:12 PM
Sorry for triple posts there but my iPhone didn't register the earlier posts. In the spring I'll have it looked at by Audi. Thanks all. I used to post here under different name from 1999 onward but lost access to that email and had to resign up to this BB.
Quick Reply: How low can you go for 1999-2002 TT Mileage
