NOOB - looking for maintenance tips
#11
You are really going to need details about the belt replacement
Thanks Vegas!
I have a pretty thorough CarFax, and at 50K there were belts replaced... but it does not explicitly specify timing belt. The shop is listed in the CarFax so I'll contact them and see if they can tell me. I purchased a service contract, will be interesting to see if they will pay to do it or not.
Russ
Russ
#12
I have the Pelican Parts BMW E36 guide, and it is great. So I popped over to their site to see what they have for the TT. I don't see a printed book like for the bimmer, but they do have some maintenance guides that look pretty good:
Audi TT & Audi TT Quattro (2000-2006) Technical Articles - Pelican Parts
I have no relationship with Pelican other than being a satisfied customer.
#14
Obviously, replacing the serpentine belt only still leaves you vulnerable. Similarly, if they replaced the timing belt but not the tensioner or water pump, you are still at risk. The 2001 model used a water pump with a plastic impellor that was notorious for breaking blades that either jammed and broke the belt or floated into the cooling system and screwed up what little flow was left from an impellor with missing teeth.
Greatly appreciate the advice!
Russ
#15
After a couple thousand miles I started seeing problems. Not un-expected in a car that has only been driven 7 or 8 thousand miles in the last 10 years.
1. Washer bottle and front 'alien' pumps went
2. Traction Control ECM module died
3. Started kicking mis-fire codes
I took her to AutoScandia in Herdon, VA for repairs and the extended service plan is oaying for most.
While the car is in the shop I asked them to replace the water pump (metal impeller) timing belt and tensioner. Car's been in the shop for two weeks while awaiting new Traction Control module from Germany. Hope to get her back next Monday, 17th April.
