Oil Filter Wrench - Hazet 3417
Old 10-31-2005, 04:20 PM
Member
stilljester's Avatar
Default Oil Filter Wrench - Hazet 3417
I changed my oil this weekend and I wanted share what I used. I noticed several people posted they had issues taking their filters off in the past. I have several different types of wrenches, (chain, 3-prong collapsible, slip collar, big channel locks - I've tried them all) This is hands down the best I've used for VW/Audi filters. If your car has a factory hard to remove filter this is the tool you need. It has never failed...
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Top.JPG">
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Bottom.JPG">
Old 10-31-2005, 04:21 PM
JustAdam's Avatar
Thank you - that will be handy
Old 10-31-2005, 04:39 PM
Teutonix's Avatar
Default I've found that a large channel-lock pliers is even easier than this tool...
I can get the filter loose by the time it takes to get this tool and socket wrench on.....
But, whatever works for you on that PITA filter!
Old 10-31-2005, 04:50 PM
Senior Member
OldSchool AG's Avatar
2nd
Old 10-31-2005, 05:24 PM
Audiboy's Avatar
Default I've used similar versions of those that slip when the oil filter is so tight...
The one I have has 3 round prongs (not flat which are weaker) that tighten their bite as you rotate the wrench.
Here's another one I have in my arsenal<ul><li><a href="http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=36778">it really bites and is very quick to use</a></li></ul>
Old 10-31-2005, 05:31 PM
Member
Default I have the three prong one two; (round bars not flat) I agree it works very very well.
Given the depth and interface this tool is made too I've never had it slip. It is a noticeably higher quality unit when compared to the knock-offs.
Old 10-31-2005, 05:41 PM
Audiboy's Avatar
Default Hmm, it's probably the same brand. But what you posted is better for tight places...
for example, I accidentally ripped off the oil pressure wire from our Acura using the 3 prong because I didn't watch out for clearance of the fingers when it pinched the wire between the motor mount.
Old 10-31-2005, 05:56 PM
furiousgeorge's Avatar
whats wrong with stabbing a screwdriver thru the filter? ; )
Old 10-31-2005, 06:18 PM
Kareem of Elise's Avatar
Default This works great every time for me.....
<center><img src="http://images14.fotki.com/v222/photos/4/469393/2730519/100_0239-vi.jpg?700525"></center><p>
Old 11-01-2005, 07:55 AM
TTapsale's Avatar
Default I got a similar one at pep boys for about $5 works fine...
<center><img src="http://pictureposter.audiworld.com/24828/bellypan.jpg"></center><p>
Quick Reply: Oil Filter Wrench - Hazet 3417
