boost problem solved (again) :-)
now i have one very very happy boostin' TT...
1. i figure that i have to use the BM with the N75 race since REVO did some tuning of the software with the N75race....now everything is boosting GREAT!!!!....after i installed the new N75 race....it even resolved the boost issue that i posted last nite regarding boost droping off too quickly.....
2. MAF is the major cause of EVERYTHING (losing boost....not boosting correctly......choking of the engine in cold morning etc.)
3. the only slight issue is that the boost will taper off quick on 4th gear to like 1.1bar (just on 4th gear) if i goes through the gears from 1-6th with WOT on each......but once it hit 5th gear back at 4k rpm it'll peak out again and hold at about 1.38-1.45bar till 5.5k rpm (and same thing at 6th gear) but i am sure it'll get better as i dun have any intake/BAMM or exhuast yet :-P (not till sept)
4. conclusion I LOVE IT!!!!!!!
Re: boost problem solved (again) :-)
Check your hoses.
I had major boost problems and it was driving me crazy. I finally brought it to the stealer and had them check it out. They said my Pressure hose comming of the Turbocharger keeps blowing off and they replaced the hose with a new one and put heavy duty clamps on it. $636 bucks later it once again runs like a champ without any power or boost loss.
Ochlockonee
04-15-2006 11:32 AM
Vodka G
06-02-2005 03:44 AM
Distinct
14
10-01-2004 11:43 AM
