What happens if you overfill your oil tank?
Old 12-20-2000, 12:29 AM
New Member
GeTTin's Avatar
Default What happens if you overfill your oil tank?
I took my car to the dealer today and got the car topped off with some conventional oil. He looked at the dipstick and said that it needs about 1/2 a quart. He poured and I checked it 10 minutes later. It was now over the max line by 2-3 centimeters. Is this bad for the car? Should I take it back to the dealership and have them take some oil out?
Old 12-20-2000, 12:32 AM
New Member
Andy P.'s Avatar
Default Re: What happens if you overfill your oil tank?
Yes! Over filling the engine can cause oil to be carried over into the induction system, which can cause damage to the catalyst.
It can also cause increased detonation, but one would hope the knock detection system can cope with that.
Andy P.
Old 12-20-2000, 12:58 AM
Levent's Avatar
Bad. Manual explains this.
Old 12-20-2000, 01:17 AM
New Member
GeTTin's Avatar
Default Re: Bad. Manual explains this.
Should I get the oil out as soon as possible? How would I do this?
Old 12-20-2000, 01:32 AM
Levent's Avatar
Default Sure ,no harm if not start the engine. But I am not sure how.....
long can you drive without harm to engine. I think it would be better to call the dealer.Because it is an important situation. No more help. Sorry.
Old 12-20-2000, 01:44 AM
New Member
LYTTSPD's Avatar
I believe also the crank could dip too far into the oil and actually causing it to foam and therefore likening the chance of air (dry spots) being pumped throught the engine. I could be completely wrong but, that is what I think I remember from auto-shop class in high school.
Old 12-20-2000, 02:13 AM
Levent's Avatar
LarryTT can answer this Q . properly. Where are you LarryTT
Old 12-20-2000, 04:15 AM
HiTEC's Avatar
That's what the standard book answer is. Give that man a cigar!
Old 12-20-2000, 04:20 AM
VAP
VAP's Avatar
Default Are you sure you mean "2-3 centimeters?" Thats 3/4" to 1 1/4" past the full mark!?!
Or between 4 & 5 quarts past full. 2-3 millimeters isnt gonna hurt much but 2-3 centimeters past the full mark could be devastating... hydro-lock the engine and like Andy said ruin the catalytic converter.
Old 12-20-2000, 04:42 AM
JustJeff's Avatar
It can also cause oil "foaming" - Drain it.
Quick Reply: What happens if you overfill your oil tank?
