Installing new seat bottom cover. Tips?
The seat bottom on my TTS was damaged by a permanent stain (ink, I think), and I've ordered a new leather cover. I plan to have an experienced auto upholstery shop install it, but I'm wondering if there are any tips, hints, or pitfalls I should be aware of. Thanks for any insight!
Are you adding a cover or replacing the material?
You are in an even worse situation if you are only doing one seat because any difference will be very obvious. Don't know who you are using but I would not replace material on 1 seat unless they guaranteed that the repair would match the stitching and lay of the other seat. And then find out in advance what they will do for you if you are not satisfied.
I solved my problem by having a thin layer of softer foam rubber added to the seat. It looks slightly puffy compared to factory but I thought the factory seats were a little to hard for my boney *** anyhow.
Let us know how it turned out
gregp1962
07-28-2011 03:15 AM
joe@vwvortex
03-14-2002 02:59 PM
