Temp gauge problem
Temp gauge problem
I have a 2008 TT and my temp gauge isn't working properly. Initially it was not working at all (at 0) then check engine light came on. I kept driving and it suddenly began working (after a few engine cool/hot cycles) and check engine light turned off.
Since then in the past few days this has happened a few additional times.
The temp gauge doesn't work then works then doesnt work...
Any ideas on what could be wrong?
I have an appt scheduled at dealer but am trying to avoid and fix myself if possible.
Thanks!
Thanks!
Our's still isn't fixed. Hopefully the check engine light fault will not cause an emissions test fail. I'm guessing it is electrical. We already had to replace a tail light assembly due to corroded connections.
calbeeze (02-27-2020)
You wouldn't happen to have part numbers available for what they replaced, would you? I already replaced one sensor to no avail. The engine light did cause us to fail emissions, but we found a work around. A bad thermostat sounds more troubling than just a wonky temp sender.
Sender 06A-919501-A
2 seal rings WHT-006-407 and N-903-168-01
Cool. Add. G-013-A8J-1G
ECS Tuning-Audi
S4 (B8 Platform) Discussion
09-09-2015 12:00 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-09-2015 11:51 AM
ECS Tuning-Audi
09-08-2015 01:08 PM
ECS Tuning-Audi
09-08-2015 11:47 AM
ECS Tuning-Audi
09-08-2015 10:42 AM
