Navigation Fails with Address Book Entries
#12
EDIT: In the meantime you can use the MMI Connect app and use it to send contacts to the car as an online destination and then pull it up through the myAudi online destinations.
#13
Yes, the MyAudi https://www.audiusa.com/myaudi
works quite well. Unfortunately the old Google Map direct transmission to vehicle is no longer supported (Google issue) but the manual entry of address in MyAudi and then automatic transmission to the vehicle works great. Just used one of my online destinations today as a matter of fact and all voice control, both the pre-call (iPhone 6S Bluetooth pairing) and the subsequent navigation (again, pre-transmitted online destination).
This is my 3rd Audi with Bluetooth tel and online Nav and it's worked quite well for me. I most often just use the direct voice entry of an address for Nav and being able to voice it all in a natural syntax has really improved in the past five years.
Ref: see "MyApps" for mobile device and "My Destinations" from Mac/PC.
#14
They renamed the option on the UI, it's called Send to your Phone and when you click on it, it lists all your devices and Car. Here's what mine looks like:
#15
OK, thanks. It didn't work for a period but they must have reactivated. Used to be able to simply right-click on a map (Mac/PC) and there was an option to direct send from there. I still don't see it (but don't what to steal this thread). My account is properly set up (just re-verified).
edit: Now I see the new format. But alas just tried direct from map to "car" and it says it can't communicate with my manufacturer and to contact them. It's said that for some time now, so.....
Say what? That's not true at all. I use this regularly and works fine. You just have to setup your car account properly with the new Google Maps under https://www.google.com/maps/sendtocar
#16
#17
A
Will do, thanks again.
Yes, this stuff was completely revamped. There was a time where the new Google Maps didn't have the Send To capabilities and one had to go back to Google Maps Classic. I don't remember when they finally ported the functionality over. You have to login to myAudi and configure the Google Maps account name you wanna use and then go over to Google Maps and configure the Send To using the same account name.
#18
Superswiss, Is it required to have an Audi Connect acct from Audi to use Google map Send to Car? My T-Mobile prepaid acct expired and I now use a US Mobile sim which uses the T-Mobile 3G network.
#19
I actually don't know. I'm curious myself, because my T-Mobile account is still active, however I'm using an unofficial AT&T subscription now. As you probably remember it's a SIM from a tablet and not an official AT&T Audi Connect subscription. My T-Mobile account expires this summer. I'm very curious if my myAudi account will stop working when that happens. I doubt it, but you'll never know. I created my myAudi account a long time ago and I don't remember what it took to get it created. But now it seems that it asks for the VIN and SIM card number. Not sure if it accepts anything other than an AT&T or T-Mobile SIM. You'll know if you try. Once you have the account the pairing between the MMI and the myAudi account is done using a PIN. I think as long as the car has a data connection it will all work. The question is if you don't already have an active myAudi account, can you create one w/o an active T-Mobile or AT&T subscription through Audi.
#20
I've had a myAudi account for over three years but haven't used it for Audi connect stuff in quite awhile. In the website I see my acct ID for Google and some destinations I created back when. I just created a new destination using myAudi and Google map Send to Car. I'll check tomorrow to see if either of them made it to the car and report back. (Too cold out to see tonite).
