Oil change- Drain or suck it out
What are list members feelings on using a suction device to remove oil?
My gearhead friend is getting one for his GTI.
I have to say that it would be a lot less messy, but wonder if it will pick up any of the heavy/settled debris?-Not that using the drain plug would necessarily eliminate that problem.
I plan on vacuuming when I do the interim 10k change myself.
After nearly 300 DIY oil changes...
… I now base the approach on the "hassle factor". On my RS5/S4 - I use the extractor method. On our SUV's that have easy access to the drain plug - I use the gravity method. My analyses that I have done from Blackstone Labs on the the extracted oil don't show any unusual buildup of sludge.
Of course, dry sump lubrication systems require gravity removal, sometimes from two/three/four locations. However, I do not currently have any cars with such lubrication systems.
Plus, on my Audi's, the filters point up so I do not have to go under of lift the car. Now, only for tire rotations and brake work.
I use the Griot's Extractor and have had it for seven years and approximately 40 oil changes with no problems.
Happy Motoring
Eric
Happy Motoring
Eric
Not the OEM. I have used aftermarket magnetic drain plugs on my prior Audi's, from ECS Tuning.
edit: I haven't yet seen a magnetic version of the MkIII TT/TTS plug as it's a somewhat unique design: https://www.ecstuning.com/b-genuine-...lug/06l103801/
btw: I have always been an under-car oil drain guy but am also opting for the lesser hassle route going forward since this oil filter is atop the engine. I have been under to install an O34 'dogbone' transmission mount stiffener and the belly pan isn't too difficult to deal with. Don't have to fully detach same.
Others that I have heard are good...
ECS Tuning has one...
Northern Tool has a multi-fluid version.
However, I am so satisfied with griot's - I was happy to spend the extra $$$
I'm a big fan of Griot's Garage products, I just happened to go with the Motive extractor (vacuum system) via ECS Tuning as I had prior gotten a Motive brake bleeder (pressurized system): https://www.ecstuning.com/b-motive-p...6-liters/1715/
Canister type Oil filter: https://www.ecstuning.com/b-genuine-...ach/06l115562/
Griot's extractor: https://www.griotsgarage.com/product...FYlWDQodFaMMgA
btw: I've historically used Mobil 1 0w-40 European formula. This engine requires 6 qt with filter change.
Related: a 32mm socket is required for oil filter canister removal, e.g. https://www.amazon.com/Assenmacher-S...+Filter+Socket
edit: I don't know how a Walmart link replaced my posted Amazon (less expensive on latter).
fe342185
08-20-2012 09:06 PM
iProDrive
32
04-28-2009 01:42 PM
