TT (Mk3) Discussion Discussion forum for the Mk3 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2014- present
Squeaky window
Old 07-28-2016, 05:48 AM
kevin880's Avatar
Default Squeaky window
When I lower or raise my drivers window it squeaks like crazy. Anyone know what I can use to stop this. Thanks
Old 07-28-2016, 09:11 AM
Huey52's Avatar
Keep your door, trunk, hood and window seals from prematurely cracking and aging with Gummi Pflege Stick!
Old 08-01-2016, 08:36 AM
4margaret's Avatar
I had the same problem. When I washed the car I got the window good and soapy. Then ran the window up and down several times. I repeated the process twice just to make sure. So far, it has been a week and the squeak is gone.
Old 08-01-2016, 09:13 AM
Huey52's Avatar
Yes, squeaky clean windows (contextual pun intended) go without saying, but good to say none the less. Again, treat the seals for a more enduring solution.
Old 08-02-2016, 07:28 AM
4margaret's Avatar
I think that the felts and rubber that are in the window track had gotten dirty causing the squeak. I could see no other way to get a cleaning solution down into the door. Running the window up and down with soapy water did just that. It really has nothing to do with treating the seals. I know my car is brand new and should not have a squeaky window from dried out seals. I will keep all the seals that are exposed to the sun and weather treated as needed over time.
arbrx
RS4 (B7 Platform) Discussion
06-16-2008 08:33 PM
A4PlayQuattro
04-03-2007 03:05 AM
Devius
10-19-2005 11:13 PM
Killer Bee
10
06-10-2003 08:29 PM
Keith
12
05-02-2000 06:00 PM
Quick Reply: Squeaky window
