TTS makes a squealing noise on cold starts
Does your TTS engine make a squealing noise for about 1/2 second on cold starts? Mine does. Audi says there are a lot of pumps and things that could be the cause, and they will check it out at my initial service call. I'm concerned that it might be a bearing noise from the alternator or AC compressor, or worse, a turbo bearing. If it is a pump as Audi guessed, then others should be hearing the same noise. Anyone else hear this noise?
Another possibility is the cabin fan
Age old trick I always used to quiet belt squeal/squeak is to take a 120 grit sanding disc and scuff the back of the belt a bit. Use extreme caution with this so you don't loose a digit if you do this while the vehicle is running. Likely best to do it before a new belt is installed. The ruffed edge will allow the belt to grip the pulleys better and not make noise. It also removes any build up which could cause noise as well.
Jason
Jason
montanamana
39
10-05-2022 09:31 AM
prophet6
10-25-2004 01:13 PM
Mr. Ricco
15
03-02-2004 03:29 PM
