TT (Mk3) Discussion Discussion forum for the Mk3 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2014- present
TTS ... Rear Suspension Noise
Old 03-02-2016, 08:55 AM
  #51
Alsof's Avatar
Originally Posted by Huey52
Good point, as usual. Dealers tend to inflate to placard, which reiterating is for full passenger/luggage load. Related, note that the driver's door-end Manufactured-by placard, at least for the US, lists vehicle Max Curb weight.
....think those Hankooks generally gives a hard/harsh ride .
If they were not that expensive to replace , would have got rid of them stat .
Tried to specify other than Hankooks when ordering the car , but no luck .
This brings me to the question as to why a German vehicle producer like Audi would choose a Korean and not a European tyre ??? ( Even sounds awful!! )
Been pumping to the spec on the door , however my sticker gives standard as well as full load pressures .......I have inflated to 2.4 bar front and 1.9 bar at rear which I discovered when taking the car to a Wheel and Tyre fitment centre as the garage attendant that checked my tyres did not use a calibrated tyre press gauge and inflated way off and over the correct
pressure .
Moral of the story - do not inflate at your filling station !
This after the tyre pressure monitor came on and when checking tyres were still perfect .....so a faulty TPM in my car ???? = Anyone else ?
Old 03-02-2016, 11:30 AM
  #52
n828cl's Avatar
Since the TPMS uses the ABS sensors, I'd expect other problems if one of those goes out. Did the TPMS alert indicate a specific wheel or all four?
After inflating or deflating any of the tires, the TPMS must be reset. It also must be reset after a significant temperature change. I'm not sure what value to use for "significant", but mine alarmed here (Minnesota) in December after having driven it in much warmer Italy for a couple of weeks in October.
- Chuck
Old 03-02-2016, 01:02 PM
  #53
Huey52's Avatar
Yep, I reset the MMI alarm threshold every time I inflate (checked at least monthly).
Note: there are no longer in-tire TPMS sensors but rather the MMI calculates a low pressure alarm based on ABS rotational data input differing from threshold. Unfortunately there is no individual tire pressure readout, as I had in my lowly Jeep.
- Chuck
Old 03-02-2016, 11:49 PM
  #54
Alsof's Avatar
TPMS left showed all four .
Reading the manual , I think it says that individual wheel problem should give you read out as to which wheel it is .
My S5 did this .
Think it could just be a glitch - I checked all at correct pressure and then re-set - let's see as this was the first time the car was on a highway doing a bit of a drive .
Old 03-03-2016, 03:34 AM
  #55
Huey52's Avatar
Yes, what I meant is that there is no all-four-wheel graphic depicting instantaneous tire pressures. I miss that from my ol' Jeep.
As you reset the threshold you should now be fine.
My S5 did this .
Old 03-03-2016, 04:12 AM
  #56
n828cl's Avatar
That's also when my spurious alert went off - about two hours into the first trip in this country. I suspect the temperature rise put the pressures out of the calculated TPMS limits. After checking the pressures and doing the reset, it hasn't happened since
- Chuck
Old 03-06-2016, 12:21 AM
  #57
Alsof's Avatar
Done - only did some 20 miles , but seems to have resolved the issue at last .
Suspension of course is a hard ride with 19" wheels + those Hankook tyres I think the culprits .....think will reduce pressure to assist for a softer ride .
What do you think ??
Back to the suspension noise -again !!
Car went in ,as still a suspension knock but not too bad ....dealer double checked that correct revised part was fitted which it was , re-assembled from start , torqued with a special tool , and much better ,except on certain corrugations on the road surface this knocking noise still appears .
Refuse to believe this standard nor acceptable , or within Audi's design spec.
Where to now ??
I believe I am going to take the car to my previous dealer where I had a specific technician that looked after all my previous cars .
He is very meticulous and thorough and perhaps the dealer that has been trying to repair this noise is looking past the issue.
Anyone agree with this second opinion strategy ?
Old 05-26-2016, 08:28 PM
  #58
jerryhze's Avatar
Wow I just took deliver of my TTS today and immediately noticed it when I drove off
googled "tts rear suspension knock" and found this thread
I would contact my dealer to find out if the fix exists as described
Old 05-26-2016, 10:31 PM
  #59
Alsof's Avatar
After fitment of the revised top shock mounting , there is still a knocking noise from the rear suspension .I took this up with Audi direct and the vehicle had to go in for all sorts of tests , photos , sound clips of the noise, etc which was sent to Germany .I was advised that there is a further revised part being made available at end May to resolve the issue ..I am anxiously waiting !
Old 05-31-2016, 04:20 AM
  #60
TOMBRADY60's Avatar
Default REAR SUPENSION NOISE
I had this also with my TTS. They had to order some rear supension parts and a special tool to put it in. Parts came right away but it took a month to get the tool. Hopefully your dealership has one. Once they replaced the parts it was perferct!
Quick Reply: TTS ... Rear Suspension Noise
