VAG-COM Discussion
Sponsored by:
Sponsored by:
"Can't sync Baud Rate" problem...
Old 01-28-2007, 06:25 PM
Kenghh's Avatar
Default "Can't sync Baud Rate" problem...
I just bought a KEY-USB and used it on my '05 3.2 TT, but could not get anything?
I tried searching module and got this message:
Address 03: ABS Brakes
Protocol: ????
Part No:
Note: Can't Synch Baud Rate
Address 08: Auto HVAC
Protocol: ????
Part No:
Please help. Thanks!
Old 01-29-2007, 06:25 AM
Bracketracer's Avatar
what exactly is printed on the OBD port end of the cable?
Old 01-29-2007, 06:30 AM
Kenghh's Avatar
Default Re: Do you mean the small sticker on the side of the connector?...
There are some codes on it...
Old 01-29-2007, 07:05 AM
Default yep
just want to make sure it's a genuine cable, and if so, I'm sure the Ross-Tech folks would be happy to help out. Also, what software version are you using?
Old 01-29-2007, 07:06 AM
Audiworld Premium Sponsor
Andy@Ross-Tech's Avatar
Default Have you tried these suggestions?
What brand/model/speed/OS is your PC? What version of VAG-COM are you using?<ul><li><a href="http://www.ross-tech.com/vag-com/faq_2.html#2.5">http://www.ross-tech.com/vag-com/faq_2.html#2.5</a</li></ul>
Andy
Old 01-29-2007, 09:07 AM
Kenghh's Avatar
Default I actually bought it used from a folk on the AW TT forum...
Is that what you mean by if it's genuine?
Thanks
Old 01-29-2007, 09:14 AM
Kenghh's Avatar
Default Yes. I tried...
And I am actually running the 6.07 version VAG-COM software on XP. The computer I'm using is a little complicated-I'm running VAG-COM in XP which is run on a MACBook CoreDuo that runs windows. Would that cause some problem?
Also, VAG-COM actually had access to the "central lock module" without problem, but having baud rate problems with ABS and HVAC, and couldn't find all other modules...
Thanks again for the help.
Old 01-29-2007, 10:37 AM
Uwe@Ross-Tech.com's Avatar
Default I bet you're using Parallels or something like that. Use Boot Camp instead.
See the "Mac (Intel):" section of the FAQ entry linked below.
-Uwe-<ul><li><a href="http://www.ross-tech.com/vag-com/faq_1.html#1.8">http://www.ross-tech.com/vag-com/faq_1.html#1.8</a</li></ul>
http://www.Ross-Tech.com
Old 01-29-2007, 01:32 PM
Kenghh's Avatar
Cool! Thanks a lot!
Old 01-30-2007, 06:19 AM
Default Mac users: Please mention the fact that you are using a Mac in your first post.
It always seems like threads like this could be resolved much more quickly and easily if the user simply mentioned the actual equipment they are using at the start of the thread. Now go forth and tell your Mac brethren. :-)
Andy
Quick Reply: "Can't sync Baud Rate" problem...
