02 allroad, 402'd, now what? Suggestions...
Central Locking Tweaks
<ul><li><a href="https://www.audiworld.com/tech/elec36.shtml">https://www.audiworld.com/tech/elec36.shtml</a</li></ul>
http://www.Ross-Tech.com
UWE: After 402, I have codes 01316 and 18036???
01316 ABS Control Module
18036 Powertrain Date Bus: Missing Message from Steering Angle Sensor
Have ESP light on, Level Control Light on, and ABS light on... one day after the 417/414 change, and the codes can't be cleared by VAG-COM.
What gives?
What gives?
Sorry, here the full scan text, I'm new to this
Tuesday,20,June,2006,17:40:22
VAG-COM Version: Release 512.4-UD
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 67 75 76
77
VIN Number: WA1YD54B82N089574
Address 01: Engine
Part No: 4Z7 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02325
WA1YD54B82N089574 AUZ7Z0A1982087
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans
Part No: 4Z7 927 156 F
Component: AG5 01V 2.7l5VT USA 1818
Coding: 01002
Shop #: WSC 02325
Address 03: ABS Brakes
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D55
Coding: 06397
Shop #: WSC 00000
2 Faults Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
18036 - Powertrain Data Bus: Missing Message from Steering Angle
Sensor
P1628 - 35-00 - -
Address 08: Auto HVAC
Part No: 4B0 820 043 AL
Component: A6-Klimavollautomat 0105
Coding: 00010
Shop #: WSC 01505
Skipping Address 15-Airbags
Address 17: Instruments
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D09
Coding: 06264
Shop #: WSC 06449
Address 34: Level Control
Part No: 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 09999
1 Fault Found:
01316 - ABS Control Module
79-00 - Please Check Fault Codes
Address 35: Centr. Locks
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D35
Coding: 15885
Shop #: WSC 02325
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
01574 - Alarm triggered by Door Contact Switch; Right Rear
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Left Rear
35-00 - -
01586 - Locking Cylinder Contact Switch; Passenger Side (F242); Close
29-00 - Short to Ground
01585 - Locking Cylinder Contact Switch; Passenger Side (F242); Open
Address 55: Xenon Range
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00030
Shop #: WSC 02325
Address 56: Radio
Part No: 4B0 035 195 J
Component: symphony II NP2 0008
Coding: 00201
Shop #: WSC 00003
End
77
Address 01: Engine
Coding: 06752
Shop #: WSC 02325
Coding: 01002
Shop #: WSC 02325
Coding: 06397
Shop #: WSC 00000
2 Faults Found:
Sensor
P1628 - 35-00 - -
Coding: 00010
Shop #: WSC 01505
Coding: 06264
Shop #: WSC 06449
Coding: 25500
Shop #: WSC 09999
1 Fault Found:
Coding: 15885
Shop #: WSC 02325
6 Faults Found:
35-00 - -
00956 - Key 2
35-00 - -
35-00 - -
Coding: 00030
Shop #: WSC 02325
Address 56: Radio
Coding: 00201
Shop #: WSC 00003
End
Definitly nothing to do with the 402 mod. There seems to be a communication issue...
...between abs and steering angle sensor, I'd check the sensor, its wiring and clear the codes afterwards.
No... read on for me...
I was assumming the problem was 402 related.
Someone else told me to "redo" the 402 mod, and then try to clear the codes, but my LF airbag let out a ton of psi when I was in the Level Control application module and in block "01" when I went to the "402" value to change it, you could feel the LF bag deflate... so I calmed down, put the car in level 2, and measured each wheel three times, then adjusted the values in each block to get me back to a 15mm drop in front and a 12mm drop in back...
I just got the car last week, and I can't get a bentley from Ross-tech, so I'm not happy at the moment...
I did put on RS4 18" with H&R 15mm spacers, do you think that has anything to do with the ABS control module or the steering angle sensor???
Is the ABS sensor just a plug near the front brakes? I'd like to avoid a trip to the dealer here.
