2014 Q5 coding help?
I have been successful coding some items but have trouble with two more.
First I have a 2014 Premium Q5, I don't have memory seats or mirrors.
1. I have tried to code the pass mirror tilt with reverse, and it works, but it doesn't tilt down as far as I would like. If I set it to tilt lower then the return normal position stops too short. I noticed that there was another check box called something like, "mirror tilt memory setting". Should I be checking this box also, and if so, then how do I set the normal and tilt positions?
2. I do have the rain/light sensor in my Q5, the rain/light sensor installed check box is not checked from the factory. My intermittent wipers do adjust automatically to the amount of rain so I don't know why the rain/light sensor installed box is not checked. I wish to change my intermittent adjustment to manual intervals and as I understand to do that you need to uncheck the rain/light sensor installed check box which it already was. Any help here?
Thanks,
Thanks,
BarryKir
01-28-2009 02:17 PM
Pitcha23
VAG-COM Discussion
09-15-2004 09:38 AM
