A4 2.0t engine sputters then turns off
Randomly the engine would sputter then turn off. It would do it whether I was driving or just sitting with the engine idling. I did not throw out any codes until yesterday. I was sitting on the side of the road for about 15 minutes trying to restart the car. Below are the codes it finally put out. If anyone could tell me what these mean I would greatly appreciate it. I have to pay out of pocket for the repairs. I am in the US military stationed in the UK and the car is US spec so I had to order it through a company here from Audi. It is a 2011 A4 2.0t with approx. 18,000 miles on it. It looks like a fuel pump issue to me but I am not sure. I have an appointment to take the car in later this week. They do not have many gasoline engines so they are not too familiar with them.
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AD HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H19 0003
Revision: E1H19---
Coding: 0104010A290F0260
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TFS0118K2907115AD 001006
ROD: EV_ECM20TFS0118K2907115AD.rod
VCID: 71E3CA91A0B23B1
3 Faults Found:
4732 - Fuel Pump
P3045 00 [032] - Electronics Defective
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 30120 km
Date: 2012.06.12
Time: 12:07:14
4735 - Fuel Pump
P3044 00 [040] - Short Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 30120 km
Date: 2012.06.12
Time: 12:05:01
2838 - Fuel Rail/System Pressure
P0087 00 [040] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 30119 km
Date: 2012.06.12
Time: 11:57:56
Readiness: 0000 0000
Thank you in advance for any assistance you may offer!
Revision: E1H19---
3 Faults Found:
4732 - Fuel Pump
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 30120 km
Date: 2012.06.12
Time: 12:07:14
4735 - Fuel Pump
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 30120 km
Date: 2012.06.12
Time: 12:05:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 30119 km
Date: 2012.06.12
Time: 11:57:56
Audiworld Premium Sponsor
I agree, it looks like the fuel pump or the fuel pump controls have gone up. The rail pressure would be the result of the fuel pump not getting the rail to the proper pressure for the injectors to work as they should.
Your symptom of sputtering and so on would also point to lack of fuel or fuel pressure.
The fact that you get the error about the electronics would lead me to question them first and the pump second.
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
Thank you for the confirmation bearthebruce. Yesterday the car decided to die again while I was driving. It would start again but then again decided not to stay running. The car is now at the dealer but the dealer can't work it in their schedule until Friday. Hopefully they can figure out what is wrong with it and get the part(s) ordered between tea breaks.
The dealer called yesterday and said that its the fuel control solenoid. I guess I will see if thats it or not in time. Thankfully they are covering under warranty here in the UK. Its still really embarking to have a car thats only a year old breakdown. What made it worse it that it happened at work and now everyone is saying I paid way too much for a car that breaks down after one year. I did remind them of a guy that went to take delivery of his new M3 and it would not start. They all got really quiet really fast.
Hi everyone, I have the same problem with the same error, and same car 2.0T NAR.
Please can you help me?
The car is no longer under warranty and I do not know exactly what should be replaced.
Address 01: Engine (0-----CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H18 0002
Revision: E1H18---
Coding: 010C010A290F0160
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
ROD: EV_ECM20TFS0118K2907115AG.rod
VCID: 74EDAD74DFA030E
3 Faults Found:
4732 - Fuel Pump
P3045 00 [047] - Electronics Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Mileage: 12635 km
Date: 2012.11.20
Time: 09:53:38
4735 - Fuel Pump
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Mileage: 12968 km
Date: 2012.11.29
Time: 08:08:14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 13229 km
Date: 2012.11.30
Time: 23:35:32
Revision: E1H18---
3 Faults Found:
4732 - Fuel Pump
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Mileage: 12635 km
Date: 2012.11.20
Time: 09:53:38
4735 - Fuel Pump
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Mileage: 12968 km
Date: 2012.11.29
Time: 08:08:14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 13229 km
Date: 2012.11.30
Time: 23:35:32
The original 2.0T as it is seems like a very good engine. Why did Audi bother changing the engine?..
Deus Ex Machina
Audi A3 / S3 / RS 3
05-11-2008 04:24 PM
RubyRedV6
12v V6 Discussion
07-16-2007 09:29 PM
