VAG-COM Discussion
Sponsored by:
Sponsored by:
A5 Cab top up - down with VAG Com Only!
Old 05-27-2014, 04:47 AM
2014Q5TDI's Avatar
Default A5 Cab top up - down with VAG Com Only!
New - Top down with Key fob - it works!
For a 2014 A5 Cabriolet, this worked to allow my key fob to make the roof go up or down. No special hardware required.
Enable Remote Operation Windows and Sunroof
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
Bit 2 - Set to 1
Then - the special trick!!!
On VCDS you go to Module 5 - which is Access/Start Authorization, then Coding 07 - change Byte 2 to 00001111 = 0F.
Mine was at 01000000 before.
then Do it!
To open/close the top via remote you have to be pretty close, approx 20 ft. On remote press "unlock" briefly then within 2 seconds press and HOLD "unlock". You'll have to keep the button pressed til it's done just like the button in the car. Close the same way just with the "lock" button.
Make sure the automatic windows controls are enabled in the MMI.
Thanks to jeffy210
Old 05-31-2014, 07:39 PM
glycerine's Avatar
Tried this today, verified it works! Performed on a 2014 S5 Cab.
https://www.facebook.com/photo.php?v...17624905250917
Old 06-02-2014, 04:35 AM
2014Q5TDI's Avatar
Old 06-02-2014, 10:47 PM
glycerine's Avatar
Also tested and confirmed on a 2013 A5 Cab.
Old 06-10-2014, 08:54 AM
wei
wei's Avatar
Does this work on a B8 2011?
Old 06-11-2014, 03:46 AM
peterpiper70's Avatar
Not working on a late 2011 S5 :-(
Old 07-28-2019, 11:13 AM
Liamjkennedy's Avatar
Default Remote roof operation
I have a 2913 A5 cab but it is not keyless start
can the fob still open the roof
Old 07-28-2019, 11:14 AM
Should be 2013 sorry
awdinut
10-11-2017 06:22 PM
Warhawk
07-11-2008 11:58 AM
Htown5vGT
09-20-2007 12:06 PM
WarrenY
12-08-2004 02:21 PM
Joey T
02-10-2003 07:54 AM
Quick Reply: A5 Cab top up - down with VAG Com Only!
