Audi A3 autoscan results, help appreciated with codes
I always get ESP on after clearing, radiator and conditioner fan are on then, EVAP canister starts ticking.
Also bothers me this:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-00 - -
01039 - Coolant Temperature Sensor (G2)
30-00 - Open or Short to Plus
Should I also check my MAF value?
Thanks!
Monday,31,March,2008,18:46:34:59447
VAG-COM Version: Release 704.1
Data version: 20071016
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 01: Engine Labels: 06A-906-033-AVU.LBL
Part No: 06A 906 033 J
Component: SIMOS33 1,6l 2V 00HS3488
Coding: 00211
Shop #: WSC 06435
WAUZZZ8LZ1A111185 AUZ5Z0A4100155
1 Fault Found:
17700 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit
P1292 - 35-00 - -
Readiness: 1110 0101
(I KNOW HERE, NEED TO REPLACE THERMOSTAT, SINCE I MANAGED TO BREAK THE SWITCH)
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.LBL
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0011266
Shop #: WSC 06435
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: None
Part No: 8L0 820 043 H
Component: A3 KLIMAAUTOMAT 0105
Coding: 01040
Shop #: WSC 06435
No fault code found.
Address 15: Airbags Labels: None
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 5008
Coding: 00104
Shop #: WSC 06435
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8L0-920-xxx-17.LBL
Part No: 8L0 920 900 F
Component: KOMBI+WEGFAHRS. M73 D53
Coding: 08042
Shop #: WSC 00000
1 Fault Found:
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Part No: 8D0 862 257 C
Component: ZV-Pumpe D16
Coding: 02049
Shop #: WSC 06435
End --------------------------------------------------------------------------------------------------
P0116 - 35-00 - -
Thanks!
Coding: 00211
Shop #: WSC 06435
1 Fault Found:
P1292 - 35-00 - -
Coding: 0011266
Shop #: WSC 06435
1 Fault Found:
Coding: 01040
Shop #: WSC 06435
Coding: 00104
Shop #: WSC 06435
1 Fault Found:
Coding: 08042
Shop #: WSC 00000
1 Fault Found:
Coding: 02049
Shop #: WSC 06435
Re: Audi A3 Engine Control Module Map
After clearing errors, these are the values what I get (engine hot, 0 rpm)
;06A-906-033-J --- Engine
;Component:SIMOS33 1,6l 2V 00HS3488, Coding:00211
1,0,,
1,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
1,2,Coolant,Temperature,Specification: 80...115 °C
;55.5°C,Temperature,
1,3,Lambda,Regulator,Specification: -10.0...+10.0 %
;0.0 %,Lambda,
1,4,Basic Setting,Requirements,see labelfile
;10110110,Bin. Bits,
2,0,Basic Functions,
2,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
2,2,Engine Load,,Specification: 24.0...35.0 %
;0.0 %,Load,
2,3,Injection,Timing,Specification: 2.0...4.0 ms
;3.09 ms,Inj. On Time,
2,4,Intake Air Mass,,Specification: 2.0...4.5 g/s
;0.00 g/s,Mass Flow,
3,0,Basic Functions,
3,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
3,2,Intake Air Mass,,Specification: 2.0...4.5 g/s
3,3,Throttle Drive,Angle Sensor 1,for EPC (G187) | Display Range: 0...100 % | Specification: 1.9...4.0 %
;8.6 %,Load,
3,4,Ignition,Timing Angle,Specification: 0...15 °BTDC
;19.5 °BTDC,Ign. Timing,
4,0,Basic Functions,
4,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
4,2,Voltage Supply,,Specification: 11.5...15.0 V
;12.32 V,Voltage,
4,3,Coolant,Temperature,Specification: 80...115 °C
4,4,Intake Air,Temperature,Specification: -38.0...+80.0 °C
;22.5°C,Temperature,
5,0,Basic Functions,
5,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
5,2,Engine Load,,Specification: 24.0...35.0 %
;0.0 %,Load,
5,3,Vehicle Speed,,Specification: 0 km/h
;0.0 km/h,Speed,
5,4,Load Status,,Display Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
6,0,Basic Functions,
6,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
6,2,Engine Load,,Specification: 24.0...35.0 %
;0.0 %,Load,
6,3,Intake Air,Temperature,Specification: -38.0...+80.0 °C
6,4,Heights Correction,Factor,Display Range: -50.0...+10.0 %
;-2.3 %,Lambda,
8,0,,
8,1,,,
; Not Oper., ,
8,2,,,
;12.32 V,Voltage,
8,3,,,
; Pump OFF, ,
8,4,,,
;0.0 mbar,Absolute Pres.,
10,0,Ignition,
10,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
10,2,Engine Load,,Specification: 24.0...35.0 %
;0.0 %,Load,
10,3,Throttle Drive,Angle Sensor 1,for EPC (G187) | Display Range: 0...100 % | Specification: 1.9...4.0 %
;8.6 %,Load,
10,4,Ignition,Timing Angle,Specification: 0..15 °BTDC
11,0,,
11,1,,,
;0 /min,RPM,
11,2,,,
11,3,,,
11,4,,,
12,0,Ignition (Position of Camshaft vs. Crankshaft),
12,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
12,2,Engine Load,,Specification: 24.0...35.0 %
;0.0 %,Load,
12,3,Crankshaft Tooth,(low > high),No. of crankshaft tooth at camshaft flank (Specification: 26...30)
;0.0,(no units),
12,4,Crankshaft Tooth,(high > low),No. of crankshaft tooth at camshaft flank (Specification: 86...90)
;0.0,(no units),
14,0,,
14,1,,,
;0 /min,RPM,
14,2,,,
;0.0 %,Load,
14,3,,,
;0,Count,
14,4,,,
; Disabled, ,
15,0,Misfire Recognition,
15,1,Cylinder 1,,
;0,Count,
15,2,Cylinder 2,,
;0,Count,
15,3,Cylinder 3,,
;0,Count,
15,4,Malfunction,Recognition,Display Range: activated/blocked
; Disabled, ,
16,0,Misfire Recognition,
16,1,Cylinder 4,,
;0,Count,
16,2,,,
16,3,,,
16,4,Malfunction,Recognition,Display Range: activated/blocked
; Disabled, ,
18,0,,
18,1,,,
;768 /min,RPM,
18,2,,,
;768 /min,RPM,
18,3,,,
;29.8 %,Load,
18,4,,,
;29.8 %,Load,
20,0,Ignition (Knock Control - Cyl 1 - 4),
20,1,Cylinder 1 Ignition,Angle Delay,Specification: 0...12 °CA
;0.0 °BTDC,Ign. Timing,
20,2,Cylinder 2 Ignition,Angle Delay,Specification: 0...12 °CA
20,3,Cylinder 3 Ignition,Angle Delay,Specification: 0...12 °CA
20,4,Cylinder 4 Ignition,Angle Delay,Specification: 0...12 °CA
22,0,Ignition (Knock Control - Cyl 1 && 2),
22,1,Engine Speed,,Specification: 640...6500 RPM
;0 /min,RPM,
22,2,Engine Load,,Specification: 40.0...100.0 %
;0.0 %,Load,
22,3,Cylinder 1 Ignition,Angle Delay,Specification: 0...12 °CA
22,4,Cylinder 2 Ignition,Angle Delay,Specification: 0...12 °CA
23,0,Ignition (Knock Control - Cyl 3 && 4),
23,1,Engine Speed,,Specification: 640...6500 RPM
;0 /min,RPM,
23,2,Engine Load,,Specification: 40.0...100.0 %
;0.0 %,Load,
23,3,Cylinder 3 Ignition,Angle Delay,Specification: 0...12 °CA
23,4,Cylinder 4 Ignition,Angle Delay,Specification: 0...12 °CA
26,0,,
26,1,,,
;4.100 V,Voltage,
26,2,,,
;4.100 V,Voltage,
26,3,,,
;4.100 V,Voltage,
26,4,,,
;4.100 V,Voltage,
28,0,Ignition (Knock Sensor Test),
28,1,Engine Speed,,Specification: 640...6500 RPM
;0 /min,RPM,
28,2,Engine Load,,Specification: 40.0...100.0 %
;0.0 %,Load,
28,3,Coolant,Temperature,Specification: 80...115 °C
28,4,Result,Knock Sensor Test,Display Range: Test ON/Test OFF/Syst. OK/Syst. not OK
; Test OFF, ,
30,0,Oxygen Sensor Status,
30,1,Bank 1,Sensor 1,Specification: 111
; 000,Bin. Bits,
30,2,Bank 1,Sensor 2,Specification: 110
; 000,Bin. Bits,
30,3,,,
30,4,,,
31,0,Lambda Regulation (Contant Operation of Lambda Probes),
31,1,Lambda Sensor,Current Value,Specification: 0.99...1.01
;1.0010,(no units),
31,2,Lambda Sensor,Specified Value,Specification: 0.99...1.01
;0.9990,(no units),
31,3,,,
31,4,,,
32,0,Lambda Regulation,
32,1,Lambda (Idle),Self-Adaptation,Specification: -14...+14
;99.2 %,Lambda,
32,2,Lambda (Partial),Self-Adaptation,Specification: -10...+10
;0.0 %,Lambda,
32,3,,,
32,4,,,
33,0,Lambda Regulation,
33,1,Bank 1,Lambda Control,Specification: 1.4...1.6 V
;0.0 %,Lambda,
33,2,Bank 1 Voltage,of Oxygen Sensors,Specification: -10.0...+10.0 %
33,3,,,
33,4,,,
34,0,Lambda Regulation (befor Catalyst - Basic Setting: Aging Check),
34,1,Engine Speed,,Specification: 2500...4000 RPM
;0 /min,RPM,
34,2,Catalytic Converter,Temperature,Specification: min. 400 °C
;328.0°C,Temperature,
34,3,Period,Duration Sensor,Specification: > 0.21
;0.000,Difference,
34,4,Result,Lambda Aging,Display Range: Test ON/Test OFF/B1-S1 not OK/B1-S1 OK
; Test OFF, ,
36,0,,
36,1,,,
;0.39 V,Voltage,
36,2,,,
; Test ON, ,
36,3,,,
36,4,,,
37,0,,
37,1,,,
;0.0 %,Load,
37,2,,,
;0.39 V,Voltage,
37,3,,,
;-0.1 %,Lambda,
37,4,,,
; Test ON, ,
41,0,Lambda Regulation (Lambda Probe Heating),
41,1,Resistance,Bank 1 Sensor 1,
41,2,Heater Condition,,Specification: Htg.bC.ON
; Htg. S1 OFF, ,
41,3,Resistance,Bank 1 Sensor 2,Specification: 96...608
;65535,Count,
41,4,Heater Condition,,Specification: Htg.aC.ON
; Htg. S2 OFF, ,
43,0,Lambda Regulation (befor Catalyst - Basic Setting),
43,1,Engine Speed,,Specification: ~1400 RPM
;0 /min,RPM,
43,2,Catalytic Converter,Temperature,Specification: min. 200 °C
43,3,Bank 1 Sensor 2,Voltage,Specification: 0.0...1.0 V
;0.39 V,Voltage,
43,4,Result,Lambda Aging,Display Range: Test ON/Test OFF/B1-S2 not OK/B1-S2 OK
; Test OFF, ,
46,0,Lambda Regulation (Basic Setting: Conversion Test),
46,1,Engine Speed,,Specification: 2500...4500 RPM
;0 /min,RPM,
46,2,Catalytic Converter,Temperature,Specification: min. 400 °C
46,3,Amplitude,Behavior,
;0.30,(no units),
46,4,Result Catalytic,Conversion,Pre-Catalytic Converter (Display Range: Test ON/Test OFF/CatConvB1 not OK/CatConvB1 OK)
; Test OFF, ,
50,0,,
50,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
50,2,Engine Speed,(specified),Specification (manual): 670...760 RPM | Specification (automatic): 800...860 RPM
;736 /min,RPM,
50,3,Condition,of A/C system,Display Range: A/C-High / A/C-Low
; OFF, ,
50,4,Operating condition,of A/C Compressor,Display Range: Compr.ON/Compr.OFF
; Compr.OFF, ,
51,0,,
51,1,,,
;0 /min,RPM,
51,2,,,
;736 /min,RPM,
51,3,,,
51,4,,,
;12.32 V,Voltage,
53,0,Speed Regulation,
53,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
53,2,Engine Speed,(specified),Specification (manual): 670...760 RPM | Specification (automatic): 800...860 RPM
;736 /min,RPM,
53,3,Voltage Supply,,Specification: 11.5...15.0 V
;12.32 V,Voltage,
53,4,Current,Consumption,Display Range: 0...100 %
;12.5 %,Load,
54,0,Speed Regulation,
54,1,Engine Speed,,Specification: 640...6500 RPM
;0 /min,RPM,
54,2,Load Status,,Display Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
54,3,Sender 2 for,Acc. Pedal Pos.,G79 (Display Range 0...100 %)
;14.1 %,Load,
54,4,Throttle Drive,Angle Sensor 1,for EPC (G187) | Display Range: 0...100 %
;8.6 %,Load,
55,0,Speed Regulation,
55,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
55,2,Idle Regulator,,Specification: -10.0...+10.0 %
;29.3 %,Load,
55,3,Idle Stabilization,Self-Adaptation,Specification: -10.0...+10.0 %
;0.4 %,Lambda,
55,4,Load Status,,see labelfile
; 00000,Bin. Bits,
56,0,Speed Regulation,
56,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
56,2,Engine Speed,(specified),Specification (manual): 670...760 RPM | Specification (automatic): 800...860 RPM
;736 /min,RPM,
56,3,Idle Regulator,,Specification: -10.0...+20.0 %
;29.3 %,Load,
56,4,Load Status,,see labelfile
; 00000,Bin. Bits,
57,0,,
57,1,,,
;0 /min,RPM,
57,2,,,
;736 /min,RPM,
57,3,,,
; Compr.OFF, ,
57,4,,,
;0.0 %,Load,
60,0,Speed Regulation (Basic Setting: Throttle Body Adaptation),
60,1,Throttle Drive,Angle Sensor 1,for EPC (G187) | Specification: 0...100 %
;17.6 %,Load,
60,2,Throttle Drive,Angle Sensor 2,for EPC (G188) | Specification: 100...0 %
;82.4 %,Load,
60,3,Self-Adaptation,Steps Counter,Specification: 0...9
;0.0,(no units),
60,4,Result,Throttle Valve Adp.,Display Range: ADP runs/ADP OK/ADP ERROR
; ADP. O.K., ,
61,0,,
61,1,,,
;0 /min,RPM,
61,2,,,
;12.32 V,Voltage,
61,3,,,
;-27.3 %,Lambda,
61,4,,,
; 0000,Bin. Bits,
62,0,,
62,1,Throttle Drive,Angle Sensor 1,for EPC (G187) | Specification: 3...97 %
;17.6 %,Load,
62,2,Throttle Drive,Angle Sensor 2,for EPC (G188) | Specification: 97...3 %
;82.4 %,Load,
62,3,Throttle Position,Sensor (G79),Specification: 6...96 %
;14.1 %,Load,
62,4,Accelerator Pedal,Position Sensor 2,G185 (Specification: 3...48 %)
;7.1 %,Load,
63,0,Speed Regulation (Basic Setting: Kick-Down Adaptation),
63,1,Throttle Position,Sensor (G79),Display Range: 0...100 %
;14.1 %,Load,
63,2,Accelerator Pedal,Position Sensor 2,G185
;87.8 %,Load,
63,3,Kick-Down,Switch,Display Range: Kick Down
63,4,Kick-Down,Adaptation,Display Range: ADP runs/ADP OK/ADP ERROR
64,0,,
64,1,,,
;0.52 V,Voltage,
64,2,,,
;4.58 V,Voltage,
64,3,,,
;0.90 V,Voltage,
64,4,,,
;4.20 V,Voltage,
66,0,Cruise Control System (CCS/GRA),
66,1,Actual,Vehicle Speed,
;0.0 km/h,Speed,
66,2,Brake switch,clutch and CCS,see labelfile
; 0000,Bin. Bits,
66,3,Specified,Vehicle Speed,
;0.0 km/h,Speed,
66,4,CCS Control,Positions,see labelfile
; 0000,Bin. Bits,
70,0,Emission Reduction (TEV - Basic Setting),
70,1,Evap. Emissions,Sol. Valve (Open),Specification: 0...100 %
;0.0 %,Load,
70,2,Oxygen Sensor,Control Deviation,
;0.0 %,Lambda,
70,3,Evap. Emissions,Sol. Valve (Flow),
;0.0 %,Lambda,
70,4,Result,Evap. Emissions,Display Range: Test ON/Test OFF/TEV OK/TEV not OK
; Test OFF, ,
74,0,Emission Reduction (Basic Setting),
74,1,Min.-Position,,Specification: 0.3...1.5 V
;0.82 V,Voltage,
74,2,Max.-Position,,Specification: 3.0...4.8 V
;3.64 V,Voltage,
74,3,Potentiometer,(actual),Specification: 0...100 %
;0.0 %,Load,
74,4,Adaptation,Status,Display Range: ADP run/ADP OK/ADP ERROR
; ADP. O.K., ,
75,0,Exhaus Gas Recirculation (Basic Setting),
75,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
75,2,Potentiometer,Value,Specification: 0...100 %
;22.0 %,Load,
75,3,Valve Stroke,Difference,Specification: -10...+25 %
;0.0 %,Lambda,
75,4,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK,,
; Test OFF, ,
76,0,,
76,1,,,
;0 /min,RPM,
76,2,,,
;0.0 %,Load,
76,3,,,
;22.0 %,Load,
76,4,,,
;0.0 %,Load,
77,0,Emission Reduction (Basic Setting),
77,1,Engine Speed,,Specification: ~1400 RPM
;0 /min,RPM,
77,2,,,
77,3,,,
;100.0 %,Load,
77,4,Result,,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK
; Test OFF, ,
80,0,,
80,1,,,
;MS--ERE 11.50.10 30 1221 , ,
86,0,,
86,1,,,
;11101101,Bin. Bits,
86,2,,,
;00111001,Bin. Bits,
86,3,,,
;00110110,Bin. Bits,
86,4,,,
;00100000,Bin. Bits,
87,0,,
87,1,,,
87,2,,,
;00000000,Bin. Bits,
87,3,,,
87,4,,,
88,0,,
88,1,,,
;10001000,Bin. Bits,
88,2,,,
;11101001,Bin. Bits,
88,3,,,
;10101000,Bin. Bits,
88,4,,,
89,0,Trip Recorder,
89,1,Distance travelled,with MIL active,
;0 km,Mileage,
89,2,Condition,"Tank Empty",Display Range: OK/too low
; OK, ,
89,3,,,
89,4,,,
92,0,,
92,1,,,
;0 km,Mileage,
92,2,,,
; OK, ,
92,3,,,
92,4,,,
95,0,Variable Intake Manifold (Single Stage Changeover),
95,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
95,2,Engine Load,,
;0.0 %,Load,
95,3,Coolant,Temperature,Specification: 80...115 °C
95,4,Variable Intake,Manifold Status,Display Range: ON/OFF
; OFF, ,
99,0,Lambda Regulation (Basic Setting),
99,1,Engine Speed,,Specification: 640...900 RPM
;0 /min,RPM,
99,2,Coolant,Temperature,Specification: 80...115 °C
99,3,Lambda Regulator,(before catalyst),Specification: -10.0...+10.0 %
;0.0 %,Lambda,
99,4,Status Lambda,Regulation,Display Range: ON/OFF
; OFF, ,
100,0,,
100,1,Readiness Bits,,see labelfile
100,2,Coolant,Temperature,
100,3,Time since,Engine Start,
;1075.2 s,Time,
100,4,OBD-Status,,see labelfile
;10000000,Bin. Bits,
101,0,,
101,1,,,
;0 /min,RPM,
101,2,,,
;0.0 %,Load,
101,3,,,
101,4,,,
102,0,,
102,1,,,
;0 /min,RPM,
102,2,,,
102,3,,,
102,4,,,
105,0,,
105,1,,,
;0 /min,RPM,
105,2,,,
;0.0 %,Load,
105,3,,,
105,4,,,
; OFF, ,
107,0,,
107,1,,,
;0 /min,RPM,
107,2,,,
;0.0 %,Lambda,
107,3,,,
107,4,,,
; Test ON, ,
120,0,Traction Control (TC/ASR),
120,1,Engine Speed,,Specification: 640...6500 RPM
;0 /min,RPM,
120,2,Engine Load,(specified),Specification: 0...399 Nm
;248.0 Nm,Torque,
120,3,Engine Load,(actual),Specification: 0...260 Nm
;0.0 Nm,Torque,
120,4,Status,,Display Range: TC active/TC n.active
; ASR OFF, ,
122,0,Transmission,
122,1,Engine Speed,,Specification: 640...6500 RPM
;0 /min,RPM,
122,2,Engine Load,(specified),Specification: 0...399 Nm
;248.0 Nm,Torque,
122,3,Engine Load,(actual),Specification: 0...260 Nm
;0.0 Nm,Torque,
122,4,Status,,Display Range: Torque red./No tor.red.
; No Torq Red, ,
125,0,CAN-Databus Communication (Powertrain),
125,1,Transmission,,
; ABS 1, ,
125,2,Brake Electronics,,
125,3,Instrument Cluster,,
; Instruments 1, ,
125,4,,,
126,0,CAN-Databus Communication (Powertrain),
126,1,,,
126,2,,,
126,3,Airbag,,
126,4,,,
130,0,Mapped Cooling,
130,1,Coolant temp.,engine outlet,Specification: 80...115 °C
130,2,Cooland temp.,radiator outlet,Specification: 0...100 °C
;33.0°C,Temperature,
130,3,Thermostat,duty cycle,Specification: 0...100 %
;0.0 %,Load,
130,4,Result,,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK
; System OK, ,
131,0,Mapped Cooling,
131,1,Coolant temp.,engine outlet,(actual) Specification: 80...115 °C
131,2,Coolant temp.,engine outlet,(specified) Specification: 0...115 °C
;94.5°C,Temperature,
131,3,Cooland temp.,radiator outlet,Specification: 0...100 °C
131,4,Thermostat,duty cycle,Specification: 0...100 %
;0.0 %,Load,
132,0,Mapped Cooling,
132,1,Coolant,temperature,radiotor outlet
132,2,Temperature,difference,between engine and radiator outlet
;0.0°C,Temperature,
132,3,Heater supply,potentiometer,Specification (w/o Climatronic): 0.2...4.8 V | Specification (with Climatronic): 0.2...5.1 V
;5.10 V,Voltage,
132,4,Cooling,Status,
; 000000,Bin. Bits,
134,0,,
134,1,,,
;90.0°C,Temperature,
134,2,,,
134,3,,,
134,4,,,
135,0,,
135,1,,,
135,2,,,
135,3,,,
135,4,,,
136,0,,
136,1,,,
; OFF, ,
136,2,,,
; OFF, ,
136,3,,,
136,4,,,
201,0,,
201,1,,,
;0,Count,
201,2,,,
;0,Count,
201,3,,,
;0.0,(no units),
201,4,,,
;00000001,Bin. Bits,
202,0,,
202,1,,,
;0,Count,
202,2,,,
;0,Count,
202,3,,,
;0.0,(no units),
202,4,,,
203,0,,
203,1,,,
;1.0 ms,Time Corr.,
203,2,,,
;-43.0 ms,Time Corr.,
203,3,,,
203,4,,,
204,0,,
204,1,,,
;-6.0 ms,Time Corr.,
204,2,,,
;0.0 ms,Time Corr.,
204,3,,,
;0.0000,(no units),
204,4,,,
;00000111,Bin. Bits,
205,0,,
205,1,,,
;0.0 ms,Time Corr.,
205,2,,,
;-1.0 ms,Time Corr.,
205,3,,,
;-2.0 ms,Time Corr.,
205,4,,,
;-7.0 ms,Time Corr.,
206,0,,
206,1,,,
;-3.0 ms,Time Corr.,
206,2,,,
;-8.0 ms,Time Corr.,
206,3,,,
;-4.0 ms,Time Corr.,
206,4,,,
207,0,,
207,1,,,
;0,Count,
207,2,,,
;1253,Count,
207,3,,,
;1639,Count,
207,4,,,
;1241,Count,
209,0,,
209,1,,,
;0 /min,RPM,
209,2,,,
;0.0000,(no units),
209,3,,,
;00000100,Bin. Bits,
209,4,,,
210,0,,
210,1,,,
;1.0010,(no units),
210,2,,,
;0,Count,
210,3,,,
210,4,,,
;11110000,Bin. Bits,
211,0,,
211,1,,,
;1.0010,(no units),
211,2,,,
;0.0 %,Lambda,
211,3,,,
;1.0,(no units),
211,4,,,
212,0,,
212,1,,,
;0.0 %,Load,
212,2,,,
;0.0 %,Lambda,
212,3,,,
;0.00,(no units),
212,4,,,
;10110000,Bin. Bits,
213,0,,
213,1,,,
;0,Count,
213,2,,,
;0 /min,RPM,
213,3,,,
;0.0 %,Lambda,
213,4,,,
214,0,,
214,1,,,
214,2,,,
;0.0 %,Lambda,
214,3,,,
;0.0 %,Lambda,
214,4,,,
;12.0,(no units),
215,0,,
215,1,,,
;0.0000,(no units),
215,2,,,
;0.00,(no units),
215,3,,,
;0.0 %,Lambda,
215,4,,,
;0.0,(no units),
216,0,,
216,1,,,
;0.0000,(no units),
216,2,,,
;0.0,(no units),
216,3,,,
;0.0,(no units),
216,4,,,
;0.0,(no units),
217,0,,
217,1,,,
;0.0 %,Lambda,
217,2,,,
;0.0 s,Time,
217,3,,,
;160,Count,
217,4,,,
218,0,,
218,1,,,
;0.0 %,Lambda,
218,2,,,
;0.0 s,Time,
218,3,,,
;160,Count,
218,4,,,
219,0,,
219,1,,,
;0.39 V,Voltage,
219,2,,,
;0.00 V,Voltage,
219,3,,,
;0.0000,(no units),
219,4,,,
;11100000,Bin. Bits,
220,0,,
220,1,,,
;0.0 %,Lambda,
220,2,,,
;-0.1 %,Lambda,
220,3,,,
;0,Count,
220,4,,,
221,0,,
221,1,,,
;0 /min,RPM,
221,2,,,
;0.0 mg/str,Mass Air / Rev.,
221,3,,,
;0.0 %,Lambda,
221,4,,,
;10011100,Bin. Bits,
222,0,,
222,1,,,
;0.0,(no units),
222,2,,,
;0.0,(no units),
222,3,,,
;0.0000,(no units),
222,4,,,
;00100010,Bin. Bits,
223,0,,
223,1,,,
;1.0010,(no units),
223,2,,,
;49.5°C,Temperature,
223,3,,,
;397,Count,
223,4,,,
224,0,,
224,1,,,
;0.0 ms,Time Corr.,
224,2,,,
;2.0 %,Lambda,
224,3,,,
;5.1 %,Lambda,
224,4,,,
225,0,,
225,1,,,
;0.39 V,Voltage,
225,2,,,
;1.0010,(no units),
225,3,,,
;-0.1 %,Lambda,
225,4,,,
226,0,,
226,1,,,
;1.0010,(no units),
226,2,,,
226,3,,,
;-0.1 %,Lambda,
226,4,,,
;01001000,Bin. Bits,
227,0,,
227,1,,,
;397,Count,
227,2,,,
;0,Count,
227,3,,,
;57,Count,
227,4,,,
;10001010,Bin. Bits,
228,0,,
228,1,,,
;0.0 %,Lambda,
228,2,,,
;0.0000,(no units),
228,3,,,
;0,Count,
228,4,,,
;10011000,Bin. Bits,
229,0,,
229,1,,,
229,2,,,
229,3,,,
229,4,,,
230,0,,
230,1,,,
;0.6875,(no units),
230,2,,,
230,3,,,
230,4,,,
231,0,,
231,1,,,
;0,Count,
231,2,,,
;0,Count,
231,3,,,
;-0.1 %,Lambda,
231,4,,,
;11100100,Bin. Bits,
232,0,,
232,1,,,
;0.0,(no units),
232,2,,,
;0.0 %,Load,
232,3,,,
;127.0,(no units),
232,4,,,
;0.0 %,Load,
233,0,,
233,1,,,
;0.0 %,Lambda,
233,2,,,
;0.0 %,Lambda,
233,3,,,
;0.0 %,Lambda,
233,4,,,
;0.0 %,Lambda,
234,0,,
234,1,,,
;0.0 ms,Time Corr.,
234,2,,,
;0.0 ms,Time Corr.,
234,3,,,
;0.0 ms,Time Corr.,
234,4,,,
;00001010,Bin. Bits,
235,0,,
235,1,,,
;57.0°C,Temperature,
235,2,,,
;0.0 ms,Time Corr.,
235,3,,,
;0.00 ms,Inj. On Time,
235,4,,,
239,0,,
239,1,,,
239,2,,,
;2.22 g/s,Mass Flow,
239,3,,,
239,4,,,
;1.07 g/s,Mass Flow,
240,0,,
240,1,,,
;969.0 mbar,Absolute Pres.,
240,2,,,
240,3,,,
;65277,Count,
240,4,,,
;10010111,Bin. Bits,
241,0,,
241,1,,,
241,2,,,
241,3,,,
;65277,Count,
241,4,,,
;10101101,Bin. Bits,
242,0,,
242,1,,,
242,2,,,
242,3,,,
;65277,Count,
242,4,,,
;00100001,Bin. Bits,
243,0,,
243,1,,,
;0.00,(no units),
243,2,,,
;-18.0,(no units),
243,3,,,
;0.0 %,Lambda,
243,4,,,
;00010011,Bin. Bits,
244,0,,
244,1,,,
244,2,,,
;167,Count,
244,3,,,
;8.6 %,Load,
244,4,,,
;00100011,Bin. Bits,
245,0,,
245,1,,,
;0.0 %,Load,
245,2,,,
245,3,,,
;5.10 V,Voltage,
245,4,,,
;01000000,Bin. Bits,
246,0,,
246,1,,,
246,2,,,
246,3,,,
246,4,,,
247,0,,
247,1,,,
247,2,,,
247,3,,,
247,4,,,
248,0,,
248,1,,,
248,2,,,
;0.0 °ATDC,Ign. Timing,
248,3,,,
;0.18 V,Voltage,
248,4,,,
;01100000,Bin. Bits,
249,0,,
249,1,,,
;0 /min,RPM,
249,2,,,
;736 /min,RPM,
249,3,,,
;0,Count,
249,4,,,
;0,Count,
250,0,,
250,1,,,
;0.72 V,Voltage,
250,2,,,
;4.48 V,Voltage,
250,3,,,
;4.22 V,Voltage,
250,4,,,
;01111001,Bin. Bits,
251,0,,
251,1,,,
;0.36 V,Voltage,
251,2,,,
;1.84 V,Voltage,
251,3,,,
;1.70 V,Voltage,
251,4,,,
252,0,,
252,1,,,
;-0.1 %,Lambda,
252,2,,,
;-0.1 %,Lambda,
252,3,,,
;0.560,Difference,
252,4,,,
;0.39 V,Voltage,
1,0,,
;0 /min,RPM,
;0.0 %,Lambda,
;0 /min,RPM,
;0.0 %,Load,
;0 /min,RPM,
;8.6 %,Load,
;0 /min,RPM,
;12.32 V,Voltage,
;0 /min,RPM,
;0.0 %,Load,
;0.0 km/h,Speed,
;0 /min,RPM,
;0.0 %,Load,
;-2.3 %,Lambda,
8,0,,
8,1,,,
; Not Oper., ,
8,2,,,
;12.32 V,Voltage,
8,3,,,
; Pump OFF, ,
8,4,,,
10,0,Ignition,
;0 /min,RPM,
;0.0 %,Load,
;8.6 %,Load,
11,0,,
11,1,,,
;0 /min,RPM,
11,2,,,
11,3,,,
11,4,,,
;0 /min,RPM,
;0.0 %,Load,
;0.0,(no units),
;0.0,(no units),
14,0,,
14,1,,,
;0 /min,RPM,
14,2,,,
;0.0 %,Load,
14,3,,,
;0,Count,
14,4,,,
; Disabled, ,
15,1,Cylinder 1,,
;0,Count,
15,2,Cylinder 2,,
;0,Count,
15,3,Cylinder 3,,
;0,Count,
; Disabled, ,
16,1,Cylinder 4,,
;0,Count,
16,2,,,
16,3,,,
; Disabled, ,
18,0,,
18,1,,,
;768 /min,RPM,
18,2,,,
;768 /min,RPM,
18,3,,,
;29.8 %,Load,
18,4,,,
;29.8 %,Load,
;0 /min,RPM,
;0.0 %,Load,
;0 /min,RPM,
;0.0 %,Load,
26,0,,
26,1,,,
;4.100 V,Voltage,
26,2,,,
;4.100 V,Voltage,
26,3,,,
;4.100 V,Voltage,
26,4,,,
;4.100 V,Voltage,
;0 /min,RPM,
;0.0 %,Load,
; Test OFF, ,
; 000,Bin. Bits,
; 000,Bin. Bits,
30,3,,,
30,4,,,
;1.0010,(no units),
;0.9990,(no units),
31,3,,,
31,4,,,
;99.2 %,Lambda,
;0.0 %,Lambda,
32,3,,,
32,4,,,
;0.0 %,Lambda,
33,3,,,
33,4,,,
;0 /min,RPM,
;0.000,Difference,
; Test OFF, ,
36,0,,
36,1,,,
;0.39 V,Voltage,
36,2,,,
; Test ON, ,
36,3,,,
36,4,,,
37,0,,
37,1,,,
;0.0 %,Load,
37,2,,,
;0.39 V,Voltage,
37,3,,,
;-0.1 %,Lambda,
37,4,,,
; Test ON, ,
; Htg. S1 OFF, ,
;65535,Count,
; Htg. S2 OFF, ,
;0 /min,RPM,
;0.39 V,Voltage,
; Test OFF, ,
;0 /min,RPM,
;0.30,(no units),
; Test OFF, ,
50,0,,
;0 /min,RPM,
;736 /min,RPM,
; OFF, ,
; Compr.OFF, ,
51,0,,
51,1,,,
;0 /min,RPM,
51,2,,,
;736 /min,RPM,
51,3,,,
51,4,,,
;12.32 V,Voltage,
;0 /min,RPM,
;736 /min,RPM,
;12.32 V,Voltage,
;12.5 %,Load,
;0 /min,RPM,
;14.1 %,Load,
;8.6 %,Load,
;0 /min,RPM,
;29.3 %,Load,
;0.4 %,Lambda,
; 00000,Bin. Bits,
;0 /min,RPM,
;736 /min,RPM,
;29.3 %,Load,
; 00000,Bin. Bits,
57,0,,
57,1,,,
;0 /min,RPM,
57,2,,,
;736 /min,RPM,
57,3,,,
; Compr.OFF, ,
57,4,,,
;0.0 %,Load,
;17.6 %,Load,
;82.4 %,Load,
;0.0,(no units),
; ADP. O.K., ,
61,0,,
61,1,,,
;0 /min,RPM,
61,2,,,
;12.32 V,Voltage,
61,3,,,
;-27.3 %,Lambda,
61,4,,,
; 0000,Bin. Bits,
62,0,,
;17.6 %,Load,
;82.4 %,Load,
;14.1 %,Load,
;7.1 %,Load,
;14.1 %,Load,
;87.8 %,Load,
64,0,,
64,1,,,
;0.52 V,Voltage,
64,2,,,
;4.58 V,Voltage,
64,3,,,
;0.90 V,Voltage,
64,4,,,
;4.20 V,Voltage,
;0.0 km/h,Speed,
; 0000,Bin. Bits,
;0.0 km/h,Speed,
; 0000,Bin. Bits,
;0.0 %,Load,
;0.0 %,Lambda,
;0.0 %,Lambda,
; Test OFF, ,
;0.82 V,Voltage,
;3.64 V,Voltage,
;0.0 %,Load,
; ADP. O.K., ,
;0 /min,RPM,
;22.0 %,Load,
;0.0 %,Lambda,
; Test OFF, ,
76,0,,
76,1,,,
;0 /min,RPM,
76,2,,,
;0.0 %,Load,
76,3,,,
;22.0 %,Load,
76,4,,,
;0.0 %,Load,
;0 /min,RPM,
77,2,,,
77,3,,,
;100.0 %,Load,
; Test OFF, ,
80,0,,
80,1,,,
86,0,,
86,1,,,
86,2,,,
86,3,,,
86,4,,,
87,0,,
87,1,,,
87,2,,,
87,3,,,
87,4,,,
88,0,,
88,1,,,
88,2,,,
88,3,,,
88,4,,,
89,0,Trip Recorder,
;0 km,Mileage,
; OK, ,
89,3,,,
89,4,,,
92,0,,
92,1,,,
;0 km,Mileage,
92,2,,,
; OK, ,
92,3,,,
92,4,,,
;0 /min,RPM,
95,2,Engine Load,,
;0.0 %,Load,
; OFF, ,
;0 /min,RPM,
;0.0 %,Lambda,
; OFF, ,
100,0,,
;1075.2 s,Time,
101,0,,
101,1,,,
;0 /min,RPM,
101,2,,,
;0.0 %,Load,
101,3,,,
101,4,,,
102,0,,
102,1,,,
;0 /min,RPM,
102,2,,,
102,3,,,
102,4,,,
105,0,,
105,1,,,
;0 /min,RPM,
105,2,,,
;0.0 %,Load,
105,3,,,
105,4,,,
; OFF, ,
107,0,,
107,1,,,
;0 /min,RPM,
107,2,,,
;0.0 %,Lambda,
107,3,,,
107,4,,,
; Test ON, ,
;0 /min,RPM,
;248.0 Nm,Torque,
;0.0 Nm,Torque,
; ASR OFF, ,
122,0,Transmission,
;0 /min,RPM,
;248.0 Nm,Torque,
;0.0 Nm,Torque,
; No Torq Red, ,
; ABS 1, ,
; Instruments 1, ,
125,4,,,
126,1,,,
126,2,,,
126,3,Airbag,,
126,4,,,
;0.0 %,Load,
; System OK, ,
;0.0 %,Load,
;0.0°C,Temperature,
;5.10 V,Voltage,
; 000000,Bin. Bits,
134,0,,
134,1,,,
134,2,,,
134,3,,,
134,4,,,
135,0,,
135,1,,,
135,2,,,
135,3,,,
135,4,,,
136,0,,
136,1,,,
; OFF, ,
136,2,,,
; OFF, ,
136,3,,,
136,4,,,
201,0,,
201,1,,,
;0,Count,
201,2,,,
;0,Count,
201,3,,,
;0.0,(no units),
201,4,,,
202,0,,
202,1,,,
;0,Count,
202,2,,,
;0,Count,
202,3,,,
;0.0,(no units),
202,4,,,
203,0,,
203,1,,,
;1.0 ms,Time Corr.,
203,2,,,
203,3,,,
203,4,,,
204,0,,
204,1,,,
204,2,,,
;0.0 ms,Time Corr.,
204,3,,,
;0.0000,(no units),
204,4,,,
205,0,,
205,1,,,
;0.0 ms,Time Corr.,
205,2,,,
205,3,,,
205,4,,,
206,0,,
206,1,,,
206,2,,,
206,3,,,
206,4,,,
207,0,,
207,1,,,
;0,Count,
207,2,,,
;1253,Count,
207,3,,,
;1639,Count,
207,4,,,
;1241,Count,
209,0,,
209,1,,,
;0 /min,RPM,
209,2,,,
;0.0000,(no units),
209,3,,,
209,4,,,
210,0,,
210,1,,,
;1.0010,(no units),
210,2,,,
;0,Count,
210,3,,,
210,4,,,
211,0,,
211,1,,,
;1.0010,(no units),
211,2,,,
;0.0 %,Lambda,
211,3,,,
;1.0,(no units),
211,4,,,
212,0,,
212,1,,,
;0.0 %,Load,
212,2,,,
;0.0 %,Lambda,
212,3,,,
;0.00,(no units),
212,4,,,
213,0,,
213,1,,,
;0,Count,
213,2,,,
;0 /min,RPM,
213,3,,,
;0.0 %,Lambda,
213,4,,,
214,0,,
214,1,,,
214,2,,,
;0.0 %,Lambda,
214,3,,,
;0.0 %,Lambda,
214,4,,,
;12.0,(no units),
215,0,,
215,1,,,
;0.0000,(no units),
215,2,,,
;0.00,(no units),
215,3,,,
;0.0 %,Lambda,
215,4,,,
;0.0,(no units),
216,0,,
216,1,,,
;0.0000,(no units),
216,2,,,
;0.0,(no units),
216,3,,,
;0.0,(no units),
216,4,,,
;0.0,(no units),
217,0,,
217,1,,,
;0.0 %,Lambda,
217,2,,,
;0.0 s,Time,
217,3,,,
;160,Count,
217,4,,,
218,0,,
218,1,,,
;0.0 %,Lambda,
218,2,,,
;0.0 s,Time,
218,3,,,
;160,Count,
218,4,,,
219,0,,
219,1,,,
;0.39 V,Voltage,
219,2,,,
;0.00 V,Voltage,
219,3,,,
;0.0000,(no units),
219,4,,,
220,0,,
220,1,,,
;0.0 %,Lambda,
220,2,,,
;-0.1 %,Lambda,
220,3,,,
;0,Count,
220,4,,,
221,0,,
221,1,,,
;0 /min,RPM,
221,2,,,
221,3,,,
;0.0 %,Lambda,
221,4,,,
222,0,,
222,1,,,
;0.0,(no units),
222,2,,,
;0.0,(no units),
222,3,,,
;0.0000,(no units),
222,4,,,
223,0,,
223,1,,,
;1.0010,(no units),
223,2,,,
223,3,,,
;397,Count,
223,4,,,
224,0,,
224,1,,,
;0.0 ms,Time Corr.,
224,2,,,
;2.0 %,Lambda,
224,3,,,
;5.1 %,Lambda,
224,4,,,
225,0,,
225,1,,,
;0.39 V,Voltage,
225,2,,,
;1.0010,(no units),
225,3,,,
;-0.1 %,Lambda,
225,4,,,
226,0,,
226,1,,,
;1.0010,(no units),
226,2,,,
226,3,,,
;-0.1 %,Lambda,
226,4,,,
227,0,,
227,1,,,
;397,Count,
227,2,,,
;0,Count,
227,3,,,
;57,Count,
227,4,,,
228,0,,
228,1,,,
;0.0 %,Lambda,
228,2,,,
;0.0000,(no units),
228,3,,,
;0,Count,
228,4,,,
229,0,,
229,1,,,
229,2,,,
229,3,,,
229,4,,,
230,0,,
230,1,,,
;0.6875,(no units),
230,2,,,
230,3,,,
230,4,,,
231,0,,
231,1,,,
;0,Count,
231,2,,,
;0,Count,
231,3,,,
;-0.1 %,Lambda,
231,4,,,
232,0,,
232,1,,,
;0.0,(no units),
232,2,,,
;0.0 %,Load,
232,3,,,
;127.0,(no units),
232,4,,,
;0.0 %,Load,
233,0,,
233,1,,,
;0.0 %,Lambda,
233,2,,,
;0.0 %,Lambda,
233,3,,,
;0.0 %,Lambda,
233,4,,,
;0.0 %,Lambda,
234,0,,
234,1,,,
;0.0 ms,Time Corr.,
234,2,,,
;0.0 ms,Time Corr.,
234,3,,,
;0.0 ms,Time Corr.,
234,4,,,
235,0,,
235,1,,,
235,2,,,
;0.0 ms,Time Corr.,
235,3,,,
235,4,,,
239,0,,
239,1,,,
239,2,,,
239,3,,,
239,4,,,
240,0,,
240,1,,,
240,2,,,
240,3,,,
;65277,Count,
240,4,,,
241,0,,
241,1,,,
241,2,,,
241,3,,,
;65277,Count,
241,4,,,
242,0,,
242,1,,,
242,2,,,
242,3,,,
;65277,Count,
242,4,,,
243,0,,
243,1,,,
;0.00,(no units),
243,2,,,
;-18.0,(no units),
243,3,,,
;0.0 %,Lambda,
243,4,,,
244,0,,
244,1,,,
244,2,,,
;167,Count,
244,3,,,
;8.6 %,Load,
244,4,,,
245,0,,
245,1,,,
;0.0 %,Load,
245,2,,,
245,3,,,
;5.10 V,Voltage,
245,4,,,
246,0,,
246,1,,,
246,2,,,
246,3,,,
246,4,,,
247,0,,
247,1,,,
247,2,,,
247,3,,,
247,4,,,
248,0,,
248,1,,,
248,2,,,
248,3,,,
;0.18 V,Voltage,
248,4,,,
249,0,,
249,1,,,
;0 /min,RPM,
249,2,,,
;736 /min,RPM,
249,3,,,
;0,Count,
249,4,,,
;0,Count,
250,0,,
250,1,,,
;0.72 V,Voltage,
250,2,,,
;4.48 V,Voltage,
250,3,,,
;4.22 V,Voltage,
250,4,,,
251,0,,
251,1,,,
;0.36 V,Voltage,
251,2,,,
;1.84 V,Voltage,
251,3,,,
;1.70 V,Voltage,
251,4,,,
252,0,,
252,1,,,
;-0.1 %,Lambda,
252,2,,,
;-0.1 %,Lambda,
252,3,,,
;0.560,Difference,
252,4,,,
;0.39 V,Voltage,
