Audi Allroad
Audi Allroad
Thursday,13,March,2008,11:18:47:27412
VAG-COM Version: Release 704.1
Data version: 20071016
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WAUZZZ4B73N009862
Address 01: Engine Labels: 059-907-401-AKE.LBL
Part No: 4Z7 907 401 B
Component: 2.5l/4VTEDC G200SG D09
Coding: 01015
Shop #: WSC 00759
Part No: 00000059
Component: 130 106EC150_1.R75035245386
WAUZZZ4B73N009862 AUZ7Z0B2156581
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: None
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D55
Coding: 06455
Shop #: WSC 00000
Address 08: Auto HVAC Labels: None
Part No: 4B0 820 043 AC
Component: A6-Klimavollautomat 0105
Coding: 00004
Shop #: WSC 02325
Address 15: Airbags Labels: None
Part No: 4Z7 959 655 H
Component: Airbag 8.4EP 2000
Coding: 0001106
Shop #: WSC 02325
1 Fault Found:
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
010 - Open or Short to Plus - Intermittent
Address 16: Steering wheel Labels: 4B0-907-487.LBL
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02325
Address 17: Instruments Labels: 4B0-920-xxx-17.LBL
Part No: 4B0 920 981 J
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 04460
Shop #: WSC 00799
Address 34: Level Control Labels: 4Z7-907-553.LBL
Part No: 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 09999
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.LBL
Part No: 4B0 962 258 N
Component: Zentralverrieg.,DWA D37
Coding: 06859
Shop #: WSC 00878
My car is a UK spec Allroad 2.5 TDI my 2002.
Bentley don't publish a book for this model.
This engine is not available,in the states.
Which is a pity,as im having problems trying
to find any info on the car.I was wondering if anyone had any experience,of the 01772 fault above,and if anyone can tell me where the
level control pressure sensor is located?
Thank's in advance
76 77
Coding: 01015
Shop #: WSC 00759
Part No: 00000059
Readiness: N/A
Coding: 06455
Shop #: WSC 00000
Coding: 00004
Shop #: WSC 02325
Coding: 0001106
Shop #: WSC 02325
1 Fault Found:
Coding: 01002
Shop #: WSC 02325
Coding: 04460
Shop #: WSC 00799
Coding: 25500
Shop #: WSC 09999
1 Fault Found:
Coding: 06859
Shop #: WSC 00878
Thank's in advance
Suspension is the same, no matter where the car is sold.
For that fault code, Bentley suggests only two possibilities:
* G291 Sensor Malfunctioning
* Connector Loose
The G291 sensor appears to be part of the valve assembly next to the compressor which also contains the valves for the individual corners (N148 to N151) and the Level Control Accumulator Valve (N311). The whole assembly would appear to be under the car, behind some sort of shielding piece next to the spare tire well.
You might want to hit the Allroad forum for more details.
-Uwe-
* Connector Loose
-Uwe-
http://www.Ross-Tech.com
Bentley is also available on-line
<ul><li><a href="http://ebahn.bentleypublishers.com/">ebahn.com</a></li></ul>
Houstonmobilian
A4 allroad (B8 Platform) Discussion
06-05-2013 08:02 PM
Kris Hansen
11-21-2012 06:03 AM
