audi wont start
audi wont start
hei everyone. i need help with my 09 Audi a6 allroad facelift. it is a 2,7 tdi 190hp. i had some problem with the dpf so i hade the software removed with the egr at the same time. i took out the ecu and sendt it in to a company and now it will not start. at all. when i try it start for half a second and then it stops. tok a vag com diagnostic:
Saturday,28,January,2017,15:50:08:23401
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
Ross-Tech: Home
VIN: WAUZZZ4F59N019768 License Plate: DN12024
Mileage: 222430km-138211mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 34 42 46 4F 52 53 55 56 5F 62
69 72 76
VIN: WAUZZZ4F59N019768 Mileage: 222430km-138211miles
01-Engine -- Status: Sporadic communication error 1000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: None
VCID: 55A1DB88BC5A3FEAAD-FFFE
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F5 910 156 N HW: 09L 927 156 C
Component: AG6 09L 2,7 TDI 140 0010
Revision: --H04--- Serial number: 4493224
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 33654510526E01DA63-8066
2 Faults Found:
006273 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 254
Reset counter: 255
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:19:51
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:19:51
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AM HW: 4F0 614 517 BD
Component: ESP8 quattro H01 0100
Revision: 00000000 Serial number: 00000000000000
Coding: 0000392
VCID: 6FED89607EC6653A47-803A
3 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 00:41:47
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0013
Hex Value: 0x8594
Hex Value: 0x00FF
02083 - Message for Delay Request
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 00:41:47
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x002B
Hex Value: 0x0594
Hex Value: 0x00FF
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 14
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:20:03
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0024
Hex Value: 0x018D
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601222045
Coding: 0000131
Shop #: WSC 02323 785 00200
VCID: 2541AB48ECBA6F6AFD-8070
Subsystem 1 - Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
No fault code found.
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 B HW: 4F1 820 043 AL
Component: KLIMABETAETIGUNGH30 0070
Revision: 00000073 Serial number: 00000000584234
Coding: 0000278
VCID: 1D3183A8C4EAA7AAA5-8048
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H22 0320
Revision: 00000000 Serial number: 4F0907279
Coding: 0013122
Shop #: WSC 02335 785 00200
VCID: 3467460C576006E27A-8060
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00146221
Shop #: WSC 02335
Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
Part No SW: 4F0 910 655 L HW: 4F0 959 655 E
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 30314236303630303032554A304C34463053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 306F4A1C6B783AC21E-8064
Crash sensor for side airbag: driver side:
Serial number: 3574SRB400008190DA67
Crash sensor for side airbag: front passenger side:
Serial number: 3584SRB40000818C9177
Crash sensor for side airbag: rear: driver side:
Serial number: 35152RB402T804A703JB
Crash sensor for side airbag: rear: passenger side:
Serial number: 35252RB40337RDMANRVA
Crash sensor for front airbag: driver side:
Serial number: 3554NRB4000047BB0F89
Crash sensor for front airbag: front passenger side:
Serial number: 3564NRB4000047A72AD7
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90026082800182
Coding: 0002042
VCID: 275DA14096B67D7ACF-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
Part No SW: 4F0 920 901 J HW: 4F0 920 901 J
Component: KOMBIINSTR. H06 0133
Revision: 00200000 Serial number: 9IT42ZMA8
Coding: 03576A0302010008010100
Shop #: WSC 02391 823 56573
VCID: 2959A77840A24B0AD9-807C
1 Fault Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 167
Reset counter: 73
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:39:27
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 F HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0024
Revision: 4LA70021 Serial number: 2100L08A198569
Coding: 000303
VCID: 326B40146D7408D268-8066
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0100
Serial number: 00000000002730359378
1 Fault Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 48
Reset counter: 73
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 00:41:48
Freeze Frame:
Bin. Bits: 00111
Voltage: 11.70 V
Count: 7
Bin. Bits: 1000
Time: 0.00 s
Address 34: Level Control Labels: None
Part No SW: 4F0 910 553 D HW: 4F0 907 553 A
Component: J197 LUFTFEDER H17 0030
Serial number: 00872000111900
Coding: 0000220
Shop #: WSC 00030 218 173784
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 2
Fault Frequency: 23
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:21:19
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Priority: 2
Reset counter: 73
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:21:20
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000100381234
Coding: 011F06204040410003
VCID: 46830CC4F1FC8472D4-8012
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01150271660000
Coding: 0139909
VCID: 31694F18A87233CA11-8064
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 150
Reset counter: 73
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:41:30
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000425687
Coding: 0001003
VCID: 5EB3C4A4896CFCB2FC-800A
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000100414569
VCID: 45810BC8CCFA8F6ADD-8010
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000521
Shop #: WSC 02145 785 00200
VCID: 2149BF58F892834A81-8074
1 Fault Found:
Freeze Frame:
Fault Status: 11100100
Fault Priority: 4
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:16:52
Freeze Frame:
Voltage: 10.66 V
Count: 241
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 3F8D19206E26D5BA97-806A
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 64
Reset counter: 33
Mileage: 222440 km
Time Indication: 0
Date: 2008.05.29
Time: 01:22:08
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 056 B HW: 4F0 035 056
Component: Radio U STD H44 0020
Revision: AB001007 Serial number: 342J/087527755
Coding: 010003020100000000
VCID: 1F4DB9A00EE6B5BAB7-804A
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4E0 035 646 B HW: 4E0 035 646
Component: B-B-ER H46 0040
Revision: -------- Serial number: 348J+087510929
Coding: 010000050002D7FD07002F0DEF7F00000201
Shop #: WSC 00030 218 94026
VCID: 2345B550228E915A93-8076
Subsystem 1 - Part No SW: 4L0 919 604 HW: 4L0 919 604
Component: DU6 Basic H43 0306
Serial number: 9355IP081006724
Subsystem 2 - Part No SW: 4F0 910 609 E HW: 4F1 919 611 M
Component: Bedienteil MM H01 0060
Serial number: 00000001201871
2 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:42:21
Freeze Frame:
Voltage: 11.20 V
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:42:31
Freeze Frame:
Bin. Bits: 10000000 00000000
Bin. Bits: 00000000 10000110
Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000100394463
Coding: 010E04204040220003
VCID: 438515D0C2CEB15AF3-8016
Address 69: Trailer (J345) Labels: 4F0-907-383.clb
Part No SW: 4F0 907 383 D HW: 4F0 907 383 D
Component: Anhaenger H06 0040
Revision: 2B002002 Serial number: 00000115014434
Coding: 0103030000000000
VCID: 2C575E6C4F505E2222-8078
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 153
Reset counter: 73
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:42:46
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100393841
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 L HW: 4F0 919 283 L
Component: Parkhilfe 4-Kan H09 0210
Revision: 00H09000 Serial number: 52220828900702
Coding: 0011416
Shop #: WSC 131071 1023 2097151
VCID: 2D515368B44A572A35-8078
End-------------------------(Elapsed Time: 03:40)--------------------------
please help me
thomas
Ross-Tech: Home
69 72 76
No Faults Found
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:19:51
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:19:51
Coding: 0000392
3 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 00:41:47
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0013
Hex Value: 0x8594
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 00:41:47
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x002B
Hex Value: 0x0594
Hex Value: 0x00FF
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:20:03
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0024
Hex Value: 0x018D
Hex Value: 0x00FF
Coding: 0000131
Coding: 0000278
1 Fault Found:
Coding: 0013122
Coding: 00056595
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Coding: 0002042
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 73
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:39:27
Coding: 000303
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 48
Reset counter: 73
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 00:41:48
Freeze Frame:
Bin. Bits: 00111
Voltage: 11.70 V
Count: 7
Bin. Bits: 1000
Time: 0.00 s
Coding: 0000220
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 23
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:21:19
Freeze Frame:
Fault Priority: 2
Reset counter: 73
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:21:20
Coding: 0139909
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 73
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:41:30
Coding: 0001003
Revision: --H05---
Coding: 0000521
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:16:52
Freeze Frame:
Voltage: 10.66 V
Count: 241
Coding: 0000004
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 64
Reset counter: 33
Mileage: 222440 km
Time Indication: 0
Date: 2008.05.29
Time: 01:22:08
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:42:21
Freeze Frame:
Voltage: 11.20 V
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 33
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:42:31
Freeze Frame:
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 73
Mileage: 222432 km
Time Indication: 0
Date: 2008.05.29
Time: 01:42:46
Coding: 0011416
please help me
thomas
kingcezar1992
A6 (C7 Platform) Discussion
13
03-05-2020 08:44 AM
danikas
A4 allroad (B8 Platform) Discussion
10-01-2014 05:48 AM
