B7 A4 light-bulb checking disable - can it be done?
Just installed a pair of white leds for the rear number plate. Of course, the leds consume less than 0.5W than the 5W each incandescent bulb consumes, so the electronics module thinks it's shorted to open, displaying that annoying lamp on my DIS even though the leds work fine (and look better). Any way to disable the light-bulb checking feature with VAG-COM through adaptation channels on module 9?
Re: Just add some high wattage resistors to equalize the load
Already tried that, 30ohms (i experimented with it and above that the error still appears) 5Watt resistors (the max size that will fit the bulb housing) but these run excessively hot! (more than the bulb itself i would say). So i ruled this possibility out.
Any other ideas?
Any other ideas?
Re: Try a higher wattage resistor - 10W
Already thought of that, but 10-watt resistors won't fit inside the bulb cover! Anyway, i dropped this project and won't experiment again until a way to disable the bulb checking disabled in the electronics module.
Audis or VWs 4Life
04-17-2004 07:22 PM
audisrock
Audi 100 / A6 (C4 Platform)
02-14-2003 09:08 AM
S4LUVR
01-20-2003 04:43 PM
SHUDS4
12-19-2002 06:20 AM
Dead
06-16-2001 04:46 PM
