VAG-COM Discussion
Sponsored by:
Sponsored by:
Can temp gauge be recoded for true reading?
Old 09-22-2016, 12:32 AM
kermac's Avatar
Location: 100 km from Canberra, New South Wales, Australia
Default Can temp gauge be recoded for true reading?
Hi
As many readers may know, the water temperature gauge on a Mk 1 TT (as well as most other Audis I believe) displays not the actual temp of the coolant but is 'weighted' to display 90 deg C if the real temp is in the range 83 deg to 98 deg (or somewhere close to that range).
You can read the actual temp either through vcds or through the display on your HVAC head unit (or additionally through such clever devices as FIS Control which reads selected values from OBD II directly to your DIS display in the middle of your instrument cluster).
I read somewhere recently that the water temp gauge can be recoded to display the real temp (this makes sense as presumably the data from the sensor is manipulated in the ecu - so it can probably be un-manipulated). Unfortunately, there was no detail.
Anyone heard of this?
Thanks all
jazz215
04-04-2007 11:54 AM
Small Town Terrorist
Audi Original "S" Cars
01-17-2007 07:34 PM
sharkTT
11-10-2003 09:18 PM
btitus
01-23-2003 06:23 AM
TimB
12-12-2002 10:22 PM
Quick Reply: Can temp gauge be recoded for true reading?
