Codes Problems
Codes Problems
Hello,
Hw: USB Cables CAN original Ross Tech
Sw: 512.4D
Car: Audi A3 8P
Is there anyone which could help me to understand this codes:
Control Module Part Number: 8P0 907 279 F
Component and/or Version: Bordnetz-SG H36 1201
Software Coding: 01884F068214100000000000000000000008FE175C0100
Work Shop Code: WSC 06314
Additional Info: 8P1955119B Wischer AU350 H01 0130
10 Faults Found:
00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
010 - Open or Short to Plus - Intermittent
00187 - Control Circuit; Relay for Supply Voltage Terminal 75X
00887 - Switch for Emergency Flasher (E229)
012 - Electrical Fault in Circuit - Intermittent
01064 - Terminal 58d; Interior Dimming
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
02071 - Local Databus
004 - No Signal/Communication - Intermittent
01516 - Terminal 30; Left
011 - Open Circuit - Intermittent
01049 - Supply Voltage Term 50
007 - Short to Ground - Intermittent
00153 - Left Windshield Wiper Motor (V216)
Thanks
Sw: 512.4D
Car: Audi A3 8P
10 Faults Found:
Thanks
Pretty sure this is a power supply issue...
...I did set up some of the most important fault codes in our Wiki, so you can look them up.
In principle you should check the ignition switch and the supply voltage at all. Have you done any changes to the car, which might cause this?<ul><li><a href="http://wiki.ross-tech.com/index.php/Category:Fault_Codes">http://wiki.ross-tech.com/index.php/Category:Fault_Codes</a</li></ul>
Re: Pretty sure this is a power supply issue...
I tried to connect wire for Internal Auto Mirror, for Rain Sensor and for Bluetooth cables..
All cables coming from Kufatec and I tried to install as instructions.
I don't know what's wrong...what do I do....a part of check igniton switch, do I need to delete others codes...
Thanks helping me
Thanks helping me
tuneda4
10
04-14-2007 06:04 PM
QuattroDrive
07-15-2005 04:07 AM
