ecu swap help...
ecu swap help...
I have an stock ecu from a 2k1 a4 1.8t fwd tip, that i want to swap to a chipped ecu from a 2k a4 1.8t quattro manual. How do i use the vag to interchange these two ecus?
The year 2000 codes that I know of:
07251 = Quattro Tip
07201 = Quattro Manual
Go to the engine module, click recode, and change the software coding to one of the above to recode your Fwd Tip ecu. Make sure you jot down the original software code (should be something like 07051 or 07151) in case something goes wrong.
beachcomber
14
07-26-2021 05:08 AM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
