The Elusive 01119 - Gear Recognition Signal (Intermittent) ABS DTC.
Just wondering if anybody ever found a solid cause as to this in the ABS controller?
I managed to find some official VAG docs online that say to check and rectify a possible fault in the gearbox controller, trouble is there is not fault there.
Noticed this fault after my tranny valve body was replaced about a year ago.
I am thinking maybe there is a shoddy line between the gearbox controller and the ABS controller, but I am unable to find a direct link in the wiring diagrams (which I am no pro at).
Is there any monitoring blocks I could watch to look for a problem?
Any input on this one is appreciated.
Auto-Scan Enclosed.
There are a tonne of faults related to the battery going dead over the winter (now have battery maintainer), cleared them all but the 01119 returned after VAG'ing a few days later.
Thursday,03,May,2007,17:25:59:50320
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAULT58E62AXXXXXX Mileage: 53670km/33348miles
Address 01: Engine Labels: None
Part No SW: 8E0 909 559 D HW: 8E0 909 059
Component: 3.0L V6/5V G 0002
Coding: 0016751
Shop #: WSC 63351
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.LBL
Part No: 8E0 927 156 Q
Component: AG5 01V 3.0l5V USA 1213
Coding: 0001002
Shop #: WSC 63351
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04497
Shop #: WSC 63351
2 Faults Found:
35-10 - - - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Part No: 8E0 820 043 G
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Part No: 8E0 907 279 E
Component: int. Lastmodul KAN 0305
Coding: 00014
Shop #: WSC 63351
2 Faults Found:
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
52-10 - Supply Voltage Too High - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Part No: 8E0 959 655 A
Component: Airbag 8.4E 3000
Coding: 0010707
Shop #: WSC 63351
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 01141
Shop #: WSC 63351
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Part No: 8E0 920 900 H
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 03000
Shop #: WSC 63351
WAULT58E62A110210 AUZ6Z0A0208021
1 Fault Found:
00668 - Supply Voltage Terminal 30
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.LBL
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0202
Coding: 00002
Shop #: WSC 63351
Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
Part No: 8E0 951 177
Component: Innenraumueberw. 0504
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
01462 - Anti-theft alarm ultra sonic Sensor (G209)
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Part No: 8E0 959 433 T
Component: Komfortgerát T5B 0617
Coding: 11788
Shop #: WSC 63351
Part No: 8E1959801E
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802F
Component: Tõrsteuer.BF BRM 0002
Part No: 8E0959801D
Component: Tõrsteuer.HL BRM 0002
Part No: 8E0959802D
Component: Tõrsteuer.HR BRM 0002
3 Faults Found:
01134 - Alarm Horn (H12)
49-10 - No Communications - Intermittent
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
Address 55: Xenon Range Labels: 4Z7-907-357.LBL
Part No: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00060
Shop #: WSC 63351
Address 56: Radio Labels: 8E0-035-1xx-56.LBL
Part No: 8E0 035 195 A
Component: symphony II NP2 0008
Coding: 00201
Shop #: WSC 63351
End --------------------------------------------------------------------------------------------------
And finally, the only DTC that came back after a few days...
Saturday,05,May,2007,12:13:09:50320
Control Module Part Number: 8E0 614 517 A
Component and/or Version: ABS/ESP allrad 1726
Software Coding: 04497
Work Shop Code: WSC 63351
1 Fault Found:
Thanks!
69 75 76 77
Coding: 0016751
Shop #: WSC 63351
1 Fault Found:
Coding: 0001002
Shop #: WSC 63351
Coding: 04497
Shop #: WSC 63351
2 Faults Found:
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
Coding: 00014
Shop #: WSC 63351
2 Faults Found:
Coding: 0010707
Shop #: WSC 63351
Coding: 01141
Shop #: WSC 63351
Coding: 03000
Shop #: WSC 63351
1 Fault Found:
Coding: 00002
Shop #: WSC 63351
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
Coding: 11788
Shop #: WSC 63351
Part No: 8E1959801E
Part No: 8E1959802F
Part No: 8E0959801D
Part No: 8E0959802D
3 Faults Found:
35-00 - -
35-00 - -
Coding: 00060
Shop #: WSC 63351
Coding: 00201
Shop #: WSC 63351
1 Fault Found:
Thanks!
Hard to find much on that code.
It usually means the ABS controller thinks there's an issue in the Tranny (see link below). But your tranny appears to be free of codes so I'm stumped.
-Uwe-<ul><li><a href="http://wiki.ross-tech.com/index.php/01119">http://wiki.ross-tech.com/index.php/01119</a</li></ul>
http://www.Ross-Tech.com
As Uwe already explained the code itself usually tells that there are codes in the tranny too...
...but in your case there obviously are not so we need to look a little further. Your whole Auto-Scan contains fault codes which seem to be caused by power supply issues. It is known that such issues can also cause incorrect fault codes to be stored, which would also be underlined by all of them being intermittent.
Yeah, battery went dead over winter. But I had this DTC previously as well.
I'll have to check/clear it again and see what goes... maybe monitor the status of CAN communication to the module.
I am thinking flaky wiring between themodules, just that I can't figure out heads or tails what line it would be from the Bentley's Wiring Diagram.
Re: The Elusive 01119 - Gear Recognition Signal (Intermittent) ABS DTC.
when scanning abs and tcm the acceleration rates were different. traction control uses calculated acceleration rates derived from the transmission speed sensor and compares them with a direct measurement. A posible cause is the accelerometer under the back seat. since im too broke to buy the sensor imma live with beep beep beep
vehicle 2002 audi a6
On mine 2002 A6 3.0 I have the same code showing in the ABS controller. Transmission shows no DTCs, clean. Not sure what it is, and how important it is. I suspect this may be a Gear Selector sensor, that is mounted on the transmission's gear selector lever. I heard this sensor is very sensitive, breaks frequently and causes some weird symptoms.
