VAG-COM Discussion
Sponsored by:
Sponsored by:
Help with 3.0 TDI (VW Marine) turbo actuator.
Old 11-30-2015, 01:57 AM
flipflap's Avatar
Default Help with 3.0 TDI (VW Marine) turbo actuator.
I am having the biggest headache with a 3.0tdi engine. The turbo actuator was replaced due to broken connector (somebody stepped on it) at a new one has been calibrated to the turbo by a specialist shop, I have also tried with a factory new turbo.
No matter what I do I get:
013128 - Control Circuit for Controller for Turbocharger 1 (J724)
P3348 - 009 - Electrical Malfunction
as soon as I turn on the ignition (start of engine is not necessary) I have tried "reset all factory defaults 00, was this a mistake?.
The actuator does not cycle on activation of ignition. I have tried with the VAG tool 6395
I have tried all the troubleshooting recommended in the service manual.
B/r
Filip
Monday,30,November,2015,10:08:07:18724
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Ross-Tech: Home
Address 01: Engine Labels: None
Control Module Part Number: 06V 910 401 HW: 06V 907 401
Component and/or Version: TDI 225-6 MD 000AG 0014
Software Coding: 0000000
Work Shop Code: WSC 00485 128 30096
VCID: 6BD5F1CF49CCD46698-5140
1 Fault Found:
Freeze Frame:
Fault Status: 01101001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Temperature: 5.4°C
Duty Cycle: 80.9 %
Voltage: 12.31 V
Duty Cycle: 0.4 %
Readiness: 0 0 X 1 X
Fearlessfigge
10-28-2014 01:58 AM
Zachman54
06-25-2006 08:39 AM
umbra
05-02-2003 06:46 PM
likmyaudi
12-27-2002 10:16 AM
S4NoRice
06-12-2002 03:29 PM
Quick Reply: Help with 3.0 TDI (VW Marine) turbo actuator.
