how accurate is vag-com torque measuring block (120)
I have APR stage 1+ 93 oct. and the max torque i get is 311nm which is about 229lb-ft of torque..any one have any ideas. or is the vag-com correct.
i've found to be inaccurate after chipping...
with a negative ~10-20% deviation from what it should be... which would make the readings VAG-COM is showing you slightly higher (+5% from my experience) than your "real" wheel hp.
after chipping, vag-com kinda freaks out taking readings. the only way to accurately gauge is to (obviously) go to a dyno, you won't get very accurate readings. also i think the larger the readings (ie, if you read 350nm as opposed to 311) i think the margin of error becomes larger (as it is based on stock chip readings, not tuned ECU readings)
make sense? probably not from my explanation =)
no - the incorrect readings are attributed the ECU being modified
coocoomike tried reverting to "stock" mode with the APR ECU and it didn't make any difference - the numbers were still off. all the numbers are based on stock "estimates" - but once the ECU is modified (soldered, re-programmed) then it's all over for accurate block 115 readings =) at least imho. good luck.
Might still be useful for measuring changes (relative differences) from mods...
but typically I just log airflow and timing (block 003) - they are the basic inputs into this torque calculation anyway.
kreativecid
Q5/SQ5 MKI (8R) Discussion
16
10-04-2021 12:30 PM
uble1234
14
10-23-2020 08:07 PM
ECS Tuning-Audi
09-30-2015 06:08 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-29-2015 11:59 AM
ECS Tuning-Audi
09-29-2015 11:54 AM
