instructions for 00 passat sought: any help here?
<ul><li><a href="https://forums.audiworld.com/allroad/threads/35960.phtml#235962">my question magically appears if you click this line!</a></li></ul>
Click
<ul><li><a href="http://wiki.ross-tech.com/index.php/17584/P1176/004470">http://wiki.ross-tech.com/index.php/17584/P1176/004470</a</li></ul>
http://www.Ross-Tech.com
Oh, yes, I went there first. It's not clear if an O2 is bad or something else causes the reading. I
understood that a "readiness codes" test identifies which of several tested items could be the culprit, if any. I wanted to eliminate or confirm those for her, and then we could better advise the independent mechanic. There seem to be no intake vacuum leaks, so I suspect an electrical or emissions issue.
Get us a scan from the car.
Chances are we have a readiness script for it which hasn't been released.
-Uwe-
-Uwe-
You mean, like this partial scan?
VAG-COM Version: Release 704.1
Data version: 20070723
Tuesday,13,May,2008,11:47:25:19240
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 94740km/58868miles
Address 01: Engine Labels: 3B0-907-551.LBL
Part No: 3B0 907 551 AN
Component: 2.8L V6/5V G 0003
Coding: 07551
Shop #: WSC 00028
1 Fault Found:
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
Readiness: 0000 0000
Address 02: Auto Trans Labels: 8D0-927-156.LBL
Part No: 8D0 927 156 AS
Component: AG5
Coding: 07551
Shop #: WSC 00028
1 Fault Found:
P1176 - 35-00 - -
Component: AG5
Beta 804.0 includes a Readiness Script for your ATQ Engine.
To run it:
[Select]
[01-Engine]
[Readiness]
[Set Readiness]
-Uwe-<ul><li><a href="http://www.ross-tech.com/vag-com/download/beta/current.html#804">http://www.ross-tech.com/vag-com/download/beta/current.html#804</a</li></ul>
[Select]
[01-Engine]
[Readiness]
[Set Readiness]
myers1.8TQ
09-22-2008 02:52 AM
myers1.8TQ
08-28-2008 07:31 AM
ar-Rings
Audi allroad
24
04-12-2008 04:48 PM
