major issues in A6 C7
Okay
after a really stupid mistake
While I was replacing the Horn fuse I pulled out some other fuses
after I started the car a few error message popped up
brake guard off
ACC off
ESC off
etc
I can't believe all this headache cuz of the bloody fuse !!!!
I couldn't clear the errors after trying few time
even an Audi dealer had look at it for 3h, they couldn't clear the errors as well, they want me to leave it for a few days
full reading below
VCDS Version: Release 15.7.3 (x64) Running on Windows 10 x64
Data version: 20151216
Ross-Tech: Home
Saturday,09,January,2016,11:15:08:18013
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 28 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90 A9 C0
VIN: WAUZZZ4G4EN128824 Mileage: 8600km-5343miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Cannot be reached 0100
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
C0-Act. for Ext. Noise -- Status: OK 0000
Address 01: Engine (J623-CGQB) Labels: Redir Fail!
Part No SW: 4G0 907 589 C HW: 4G0 907 589
Component: 3.0BTD EDC17 H25 0002
Revision: 57H25---
Coding: 4A2A4032256603020000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30BTD0114G0907589C 001002
ROD: EV_ECM30BTD_AU57.rod
VCID: 3467F4CC9F7D329EA5-8060
2 Faults Found:
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [047] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:46
10586 - Door Control Module - Rear Left
U0201 00 [038] - No Communications
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:43
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4G0 927 158 K HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H16 1005
Revision: --H16---
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_AU48.rod
VCID: 3663CEC48901208E9B-8062
1 Fault Found:
12561 - No Communications with Steering Angle Sender (G85)
U0126 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:45
Address 03: ABS Brakes (J104) Labels: 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Revision: -------- Serial number: --------------
Coding: 49A78F0192E5F180CB00
ASAM Dataset: EV_ESPPremiAU57X 004039
ROD: EV_ESPPremiAU57X_AU57.rod
VCID: 3B75DFF0B223FDE664-806E
1 Fault Found:
0067 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:54
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 ET HW: 4H0 907 064 ET
Component: BCM2 2.0 H36 0521
Revision: 00002001
Coding: 05B82F06000000000000
VCID: 7F0DEBE0EEBB21C608-802A
2 Faults Found:
03285 - Sensor for Contact with Door Handle; Front Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 8524 km
Time Indication: 0
Date: 2016.01.08
Time: 15:33:51
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Time Indication: 0
Date: 2016.01.09
Time: 11:02:43
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4G0 820 043 AL HW: 4G0 820 043 AL
Component: KLIMA 4 ZONEN H14 0093
Serial number: 13021400041529
Coding: 362160782D
ASAM Dataset: EV_AirCondiComfoUDS 004003
ROD: EV_AirCondiComfoUDS.rod
VCID: 69D955B8883FBF76C6-803C
1 Fault Found:
0318 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:43
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001846386
Coding: 0907201009749FE2818100C480001800CF9DC3082F08020180 0108546F01
VCID: 6FED3BA0BEDB514698-803A
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 140208 H37 0080
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Time Indication: 0
Date: 2016.01.08
Time: 13:12:00
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061406401603
Coding: A8EB06
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000.rod
VCID: 71E93DD8A0EF47B68E-8024
1 Fault Found:
13679386 - Databus
U1123 00 [008] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 232
Mileage: 8523 km
Date: 2016.01.08
Time: 15:09:58
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Serial number: 00000000000000
Coding: 7E04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X.rod
VCID: 285F10BC53B5467E19-807C
5 Faults Found:
32512 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:55
37376 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:43
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:55
82688 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 192
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:43
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 192
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:55
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00GYHDW
Coding: 30323436313330303536554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
Crash sensor for side airbag; driver side:
Serial number: 3575HRB40512B0IQ49RA
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB405B0N3MG60UO
Crash sensor for side airbag; rear; driver side:
Serial number: 3515JRB400250T8ACI7.
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525JRB400O50T8ACA24
Crash sensor for front airbag; driver side:
Serial number: 3554VRB400Q50TIUD11+
Crash sensor for front airbag; front passenger side:
Serial number: 3564VRB400I50SAEDOUI
1 Fault Found:
1050112 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:12:00
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372NBI000W6
Coding: 0000FC
VCID: 377DC3C0860BD98680-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0010
No fault code found.
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 933 B HW: 4G8 920 933 B
Component: TDieRdwAcc H58 0621
Revision: 29460235 Serial number: 658240214592034
Coding: 338608000F510008010000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 2F6DFBA0765B1146D8-807A
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001287886
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001019
ROD: EV_GatewPkoUDS.rod
VCID: 72EB32D4A5E97CAE77-8026
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 2081582603
Voltage stabilizer:
2 Faults Found:
5074 - Door Control Module - Rear Left
U0201 00 [008] - No Communications
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:42
4230 - No Communications with Steering Angle Sender (G85)
U0126 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:12:02
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 7CF71CECFFAD3ADE2D-8028
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 M HW: 4G0 919 158 M
Component: KLIMA FOND H08 0093
Serial number: 20021400041507
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: 3979C5F8B81FCFF676-806C
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000090995271
Coding: 00781B0000006001000001010101102030303232203232
VCID: 77FD03C0C68B198640-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H03 0056
Revision: -------- Serial number: EJ1BPA8206E91Y
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_AU57.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0060
Revision: 00H03000 Serial number: 6PZ 010 287-03
Coding: 0001101
VCID: 306FF8DCA3650EBEC1-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0060
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F26.02.1400H03000AMS15766ÿ
Subsystem 4 - Serial number: S15766ÿ
1 Fault Found:
02854 - Warning Lamp for Lane Change Assistance (in right exterior mirror) (K234)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 192
Mileage: 0 km
Time Indication: 0
Date: 2014.01.01
Time: 00:00:00
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F16005E01628002080013
VCID: 4581B908CCE7BB1602-8010
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Time Indication: 0
Date: 2016.01.09
Time: 11:02:43
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H40 0010
Revision: 00001000 Serial number: 0009298354
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
VCID: 326BF2D465693CAEB7-8066
2 Faults Found:
3158276 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Reset counter: 192
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:59
4208000 - Steering Angle Sensor
B1168 F1 [008] - Synchronization Failed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 232
Mileage: 8523 km
Date: 2016.01.08
Time: 15:09:57
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0327934505
Coding: 01000E2A00B93085832008040E030E47000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Coding: 901F00
Subsystem 2 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 192
Mileage: 8523 km
Time Indication: 0
Date: 2016.01.08
Time: 13:11:56
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Time Indication: 0
Date: 2016.01.09
Time: 11:02:43
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000074527
Coding: 030000
VCID: 1D31316804F793D67A-8048
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0507
Coding: 011F16005E01628002080002
VCID: 4683BE04F1E1B00E0B-8012
2 Faults Found:
02117 - Motor for Mirror Folding
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 190
Mileage: 8524 km
Time Indication: 0
Date: 2016.01.08
Time: 15:41:51
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Time Indication: 0
Date: 2016.01.09
Time: 11:02:47
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H03 0015
Revision: -------- Serial number: 00000000976140
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 2D51E1A87C576356EA-8078
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 140224-0002-066
Coding: 1121A6601000A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 061 N HW: 4G0 035 061
Component: Radio U DAB H60 0139
Revision: AB001007 Serial number: 109B/0E7872266
Coding: 040103010000000001
VCID: 285F10BC5BB5467E19-807C
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 754 J HW: 4G0 035 754 H
Component: H-BN-RW H52 0798
Revision: -------- Serial number: 191B40E7558667
Coding: 050A01000003E9EF7D90CB2E00000003FC0001020000000000
VCID: 2D51E1A874576356EA-8078
Subsystem 1 - Part No: 8R0 060 884 BN
Component: ROW 2014 0605
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Subsystem 3 - Part No SW: 4G2 919 610 C HW: 4G2 919 610 C
Component: E380 BDT C7 H11 0204
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5571
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0507
Coding: 010F14004001628002080002
VCID: 4999B538E0FF5F76E6-801C
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4H0 907 428 B HW: 7P6 907 441 D
Component: TopView H05 0220
Revision: 11001001 Serial number: 82330JF0135217
Coding: 0200000001000000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
ROD: EV_CamerSysteTopViewAUDI.rod
VCID: 2C57ECAC474D6A5EFD-8078
2 Faults Found:
13701388 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:54
9617434 - Supply Voltage for Left Surroundings Camera
B1286 14 [009] - Open or Short to Ground
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:54
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G5 959 107 B HW: 4G5 959 107
Component: HDSG-Modul H01 0043
Revision: 13001001 Serial number: 041400074
Coding: 111104C000
ASAM Dataset: EV_HDSGAu571 001022
ROD: EV_HDSGAu571.rod
VCID: 3169FDD8606F07B6CE-8064
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0507
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: -------- Serial number: 262130025421000
Coding: 6A060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 26431E8459A1500E2B-8072
1 Fault Found:
0722 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:52
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7E04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X.rod
4 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:53
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:43
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:53
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 192
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:43
Address 8E: Image Processing (J851) Labels: 4G0-907-107.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000122802147
Coding: 04C018180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
4 Faults Found:
0028 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:12:01
0043 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:12:01
0147 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 232
Mileage: 8523 km
Date: 2016.01.08
Time: 15:09:58
0170 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 232
Mileage: 8523 km
Date: 2016.01.08
Time: 15:09:57
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308004240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
1 Fault Found:
12583690 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:56
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:57
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 4G0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 140220200472
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 2B55EFB042436D66F4-807E
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 B HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0007
Serial number: 140217202024
ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS.rod
VCID: 2447048C2F9DA21E35-8070
brake guard off
ACC off
ESC off
etc
full reading below
Ross-Tech: Home
Revision: 57H25---
2 Faults Found:
U0126 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:43
Revision: --H16---
Coding: 000001
1 Fault Found:
U0126 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:45
1 Fault Found:
U1111 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:54
Revision: 00002001
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 8524 km
Time Indication: 0
Date: 2016.01.08
Time: 15:33:51
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Time Indication: 0
Date: 2016.01.09
Time: 11:02:43
Coding: 362160782D
1 Fault Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:43
Coding: 0045F7
Coding: 02006D
Coding: 110000
Coding: 110000
Coding: 020300
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Time Indication: 0
Date: 2016.01.08
Time: 13:12:00
Coding: A8EB06
1 Fault Found:
13679386 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 232
Mileage: 8523 km
Date: 2016.01.08
Time: 15:09:58
Coding: 7E04010202
5 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:55
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:43
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:55
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 192
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:43
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 192
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:55
1 Fault Found:
1050112 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:12:00
Coding: 0000FC
ROD: EV_RBD4K.rod
Coding: 00CD077D00
Voltage stabilizer:
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:42
U0126 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:12:02
Revision: AA001002
Coding: 22
Coding: 0001101
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 192
Mileage: 0 km
Time Indication: 0
Date: 2014.01.01
Time: 00:00:00
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Time Indication: 0
Date: 2016.01.09
Time: 11:02:43
ROD: EV_RCEPS.rod
2 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Reset counter: 192
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 232
Mileage: 8523 km
Date: 2016.01.08
Time: 15:09:57
Coding: 901F00
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 192
Mileage: 8523 km
Time Indication: 0
Date: 2016.01.08
Time: 13:11:56
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Time Indication: 0
Date: 2016.01.09
Time: 11:02:43
Coding: 030000
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 190
Mileage: 8524 km
Time Indication: 0
Date: 2016.01.08
Time: 15:41:51
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Time Indication: 0
Date: 2016.01.09
Time: 11:02:47
2 Faults Found:
13701388 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:54
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:54
Coding: 111104C000
Coding: 6A060000
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:52
Coding: 7E04010202
4 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:53
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:43
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:53
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 192
Mileage: 8600 km
Date: 2016.01.09
Time: 11:02:43
ROD: EV_BC7.rod
4 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:12:01
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:12:01
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 232
Mileage: 8523 km
Date: 2016.01.08
Time: 15:09:58
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 232
Mileage: 8523 km
Date: 2016.01.08
Time: 15:09:57
ROD: EV_RGS_L.rod
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:56
ROD: EV_RGS_R.rod
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 8523 km
Date: 2016.01.08
Time: 13:11:57
Hi having same issue with my A7 after routing around in the fuse box checking for blown one for my rear boot spoiler.
did anyone get this sorted as the VCDS isn't picking them up
VIN: WAUZZZ4G7CN097145 Mileage: 148487km-92265miles
10-Park/Steer Assist -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
30-Special Function II -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Cannot be reached 0100
5F-Information Electr. -- Status: Malfunction 0010
galaxys (06-03-2023)
