Problem: 55 xenon range can not be reached
Hi everyone!
First of all, sorry for my english cause I'm spaniard
I have an A3 sportback from 2005 which originaly has halogen headlights from factory.
Recently I have upgrade it with OEM bi-xenon (without AFS) headlights. All done and working OK.
Afther that I have also installed the OEM aLWR system. And here is when my problem began...
After the phisycal installation I conected my vagcom (10.6) to calibrate the auto leveling lights syste, and I followed these instructions:
- Enter module 19 can-gateway and activate at byte 0 the xenon range bit
- Then I enter module 55 xenon range but... I got no response from module.
I have checked the connections wires with a tester and everything seems OK... Any idea of the problem?
- Could it be a faulty aLWR module??
- Should I neet to upgrade the vagcom version??
Thanks in advance for the response!
The other post was closed so I couldn't answer. The vagcom cable I'm using was bought at a second-hand website www.segundamano.es
It cost me about 100 euros, as you can see I'm not an expert on that kind of things... In fact I didn't know that there were genuine ones and pirate ones. So now I realise that mine is a pirate one. I'm sorry about that!
I would try to solve the problem by my own... sorry for the inconveniences.
regards!
Finaly I solved the problem...
At the 20 pin aLWR conector I just have to change the pin 2 (canbus-H) by the pin 3 (canbus-L) and vice versa ... now everything works
I hope it helps somebody!
regards!
regards!
maxpistoia
A4 (B7 Platform) Discussion
12-19-2008 04:23 AM
SteveMondragon
VAG-COM Discussion
01-25-2006 07:30 PM
