Problems with block 32
Hello, until yesterday I had Dtc 17536 and 17538, trim too lean. I Changed the Maf and made an adjustment basic of block 060. I scanned 032 block and these are the values:
<a href="http://img354.imageshack.us/my.php?image=mafnuevo3ls.jpg" target="_blank"><img src="http://img354.imageshack.us/img354/1272/mafnuevo3ls.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
and this is the graphic of the mafs:
<a href="http://img481.imageshack.us/my.php?image=newmaf3ek.jpg" target="_blank"><img src="http://img481.imageshack.us/img481/3097/newmaf3ek.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
The problen is the secon file block 32 says 0.0, Why? need more time for adaptation?
Old maf: With dtcs; 17536 and 17538.
<a href="http://img481.imageshack.us/my.php?image=lambda2cm.jpg" target="_blank"><img src="http://img481.imageshack.us/img481/5219/lambda2cm.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
New maf: No DTCS AUTOSCAN
Why 0.0? Thx a lot
Why 0.0? Thx a lot
Re: When you clear fault codes, both reset to 0.0
how time can it takes more or less? and why the 4 file is not 0.0 also?
Do you think is correct this maf, i have a 2.7 biturbo 230hp, thx
Why do you consider this to be a problem?
Values close to 0 are good!
-Uwe-
-Uwe-
http://www.Ross-Tech.com
I wouldn't let that bother me unless it throws some DTC.
How many miles have you put on the car since you last cleared fault codes?
-Uwe-
-Uwe-
3 miles isn't near enough for those numbers to be meaningful.
Drive the car for a few days, including some time on the highway, then check 'em again.
-Uwe-
-Uwe-
Monkeyboy
VAG-COM Discussion
07-12-2008 04:44 PM
Alphaville
05-02-2006 04:47 PM
patience
12v V6 Discussion
05-19-2004 06:46 AM
