VAG-COM Discussion
Sponsored by:
Sponsored by:
Trouble with 2013 S4 Windows Down/Up Mod
Old 02-12-2015, 07:22 AM
jmphegle's Avatar
Default Trouble with 2013 S4 Windows Down/Up Mod
Hi Everyone, Appreciate any help you can provide here. Im using a Ross-Tech's HEX-COM + CAN v.908 (limited by windows 98).
Thought we were on the right track with the instructions below but after saving, the windows have done nothing. I've tried just holding the unlock for a straight 10 seconds and also pushing once then holding for an extended period. Does anyone know if I'm missing something or if there is anything I need to have unchecked to make this happen? Also, the key I'm using is whatever standard smart key that came with the car that I don't have to have connected to actually start the car.
Enable Remote Operation Windows and Sunroof
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
Bit 2 - Set to 1
Old 02-14-2015, 04:31 AM
Audiworld Premium Sponsor
bearthebruce's Avatar
The problem may well be that you are working with a 5 year old version of VCDS on a car that is 2 years old... 908 was released in 2009.. the data in that unit does not support 2013 models. I'm not saying for certain that this is causing troubles but I would not be surprised if that was the issue.
Find someone with a current install VCDS and have them try.
-Bruce-
Ross-Tech, LLC
Old 04-16-2015, 08:05 PM
Club AutoUnion
Mrclopec's Avatar
Activated it on a '14 B8 S4 and was stumped for an hour or so trying to figure out why the windows wouldn't roll up or down with the FOB. Turns out one you activate it in VAG COM you have to go into your MMI under central locking and turn it on. You should be able to choose between front, rear and sunroof or any combination of the three.
tutone
VAG-COM Discussion
05-23-2018 03:43 AM
Naota
S4 (B8 Platform) Discussion
13
07-12-2013 07:15 AM
Redmangohtx
03-18-2013 05:47 PM
mdwsta4â„¢uroslut
17
05-28-2005 12:36 PM
xxsnsxx
9
04-05-2001 07:34 AM
Quick Reply: Trouble with 2013 S4 Windows Down/Up Mod
