VAG-COM Discussion
Sponsored by:
Sponsored by:
vag com ????
Old 06-28-2015, 06:08 AM
niedzial1983's Avatar
Default vag com ????
guys
is this the real deal ? full cable that allows codding ?
VAG COM VAS Diagnostic Kit
Old 06-28-2015, 06:37 AM
snagitseven's Avatar
If you want to be sure of full coding capability and future compatibility through updates, there is only one that our forum members are certain will work now and in the future - Ross-Tech's VCDS cable and software. Not inexpensive but a complete hardware and software tool with assured performance and longevity that we can rely on.
Old 06-28-2015, 08:00 AM
thanks
same as this one , seem to cheap but it says it does it all
FULL VAG COM PRO VCDS HQ DIAGNOSTIC TOOL KIT CABLE SOFTWARE ROSS TECH HEX CAN USB 2015 VW AUDI SEAT | United Kingdom | Gumtree
hard to know....
Old 06-28-2015, 04:10 PM
Originally Posted by niedzial1983
thanks
hard to know....
That is NOT
Old 06-28-2015, 04:17 PM
That is NOT a Ross Tech cable but a counterfeit using their name. Ross-Tech sells the cables on their website. These knock off cables are usually made in China and while they may work for some things, as soon as Ross Tech updates their firmware or software these can be come less useful than a bungee cord. As I wrote before, if you a product that can do full coding now and in the future, get the Ross Tech VCDS cable. If all you want to do is change a few common things and read codes, check out the inexpensive Carista app with a cheap OBDII dongle (do an AW search). Both Ross-tech and Carista are sponsors of AudiWorld.
Old 06-30-2015, 07:47 AM
thanks for the info
looking at all this i dont have the money to spend on a ross tech cable , and do i need updates for my 2006 car probably not . will i want to use it for my next car , no idea , ....
30 pounds option is best for me i think
VCDS 12.12.0 VAGCOM VAG COM: Amazon.co.uk: Electronics VCDS 12.12.0 VAGCOM VAG COM: Amazon.co.uk: Electronics
Old 07-10-2015, 07:01 AM
Crack O'Deal's Avatar
niedzial1983, please share your experience with that 30 pounds option. I am also looking into inexpensive option for private use (and not a professional garage) to check/reset fault codes. No updates required, no serious programming or tuning. Just to know whether the condition of the car is critical and there is a need to take the car immediately to garage or book and appointment let's say next week... or even reset the code and be happy.
Old 07-14-2015, 04:40 AM
CharlesElliott's Avatar
As long as you are aware that that is almost certainly a pirated/copy version, and so that is why it is cheap.
Old 07-14-2015, 06:32 AM
If all you want to do is change a few mods and run scans, this might be your best option:
Carista OBD2 - Vehicle Diagnostics and Customization | brew your own car
You can also search the forums for threads on this product as they are an AW sponsor.
Old 07-14-2015, 10:12 AM
snagitseven
this sounds like a good solution . Thanks
i have read up about fake cables online and there seems to be a lot of problems with them ...
i will go fot the Carista obd2
Quick Reply: vag com ????
