VAG COM problem
VAG COM problem
I replaced an aftermarket radio with Concert II and now, I need to recode my C5's Instrument Cluster (17) in order to get all features (like GALA, buttons illumination etc.) of Concert II in use. But there is a little problem; I have cheked out correct value of recoding from Openobd.org, but it doesn't work.
According instructions of Openobd.org, the new value should be coded to canal 61 but it isn't possible because it accept only values 1 or 2. Correct value is 04352.
The controller is 4B0 920 900 R, so instrument cluster is "midline" and my VAG COM Release is 311-2.
Have anybody any idea what I am missing?
You should check channel 62 and not 61, a current version of VAG-COM/VCDS would give you...
...the proper table of values when accessing the adaptation channel.
Re: You should check channel 62 and not 61, a current version of VAG-COM/VCDS would give you...
Yes, indeed I checked both and non of them doesn't gave me a proper table. Channel 62 gave a message; "ERROR CHANNEL 62 NOT AVAILABLE". Any other ideas?
maaliish
08-18-2006 07:09 AM
Pearly
09-19-2005 08:20 AM
NSX JR
04-11-2005 12:25 PM
stupidrobothead
VAG-COM Discussion
08-21-2003 05:34 AM
