VAG noobie here... What does it mean? RS4 4.2V8
Guest
Just received my cable and cleared all my misfire codes but still have this one.
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 - Implausible Signal
It means you should check fault codes at address 11-Engine II
The RS4 has two ECUs, one for each cylinder bank.
01-Engine is ECU number 1.
11-Engine II is ECU number 2.
On the Select Control Module screen, click the Chassis tab, then you'll find the button for 11-Engine II.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
SKIroad'r
NY / NJ / CT Discussion
06-24-2008 03:48 PM
Farach
03-27-2003 01:47 PM
