Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Will 18 in Q5 rims fit A6
Old 04-25-2015, 09:06 AM
RIAUDI's Avatar
Default Will 18 in Q5 rims fit A6
I have been doing some research looking for a set of 18in OEM Rims that I would be able to use for winter tires on a 2016 A6 TDI. I have found the most common one listed for the A6 is the 18in #58995 5X112 ET39 8in wide. They are available from several different remanufacture suppliers for around $200 each. I have also found a set which is available locally with tires mounted for about the same price. The rims and tires are off a Q5. They are 18 in #58917 5X112 ET39 8in. All the specs for the rims seem to be identical. Obviously the tire would be of no use on a A6 being they are much to large. But I could possibly use them on another family vehicle or sell the tires separately. Has anyone tried these rims on a A6? It would seem to me they should fit or am I missing something.
Old 05-03-2015, 08:20 AM
AudiWorld Expert
Reggie's Avatar
Looks like you have done your homework. It would appear they would fit fine.
Old 05-04-2015, 10:30 AM
RIAUDI's Avatar
Thank you for the reply
Old 11-05-2018, 07:28 PM
Eric Shapiro's Avatar
Did the Q5 wheels on the A6 work out for you? I am looking to do the same thing, taking 18” wheels off a 2014 Q5 and using them as a winter tire set.
da8472
24
07-01-2010 09:02 PM
nerdslayer
10-02-2009 04:12 PM
jjsA4
04-23-2004 06:31 AM
silverQA4
01-26-2003 07:01 PM
edhu
02-26-2001 03:34 PM
Quick Reply: Will 18 in Q5 rims fit A6
