1.8T AEB - Giac PC 16 - fuel pressure, part throttle behavior
Old Jan 12, 2013 | 04:31 AM
vtraudt's Avatar
Default 1.8T AEB - Giac PC 16 - fuel pressure, part throttle behavior
I have the standard PC16 setup (315cc, AFPR, FMIC, DP).
Car runs tame (15 psi boost) under WOT runs.
But under part throttle, all hell breaks loose. Boost climbs to 25 psi (or higher?), car runs like a bat out of hell (scary).
Fuel pressure was initially set low (under 2.7 bar = 39 psi); I raised it to the giac stock 3.0 (43.5 psi) bar.
Only change I noticed is that it now take a bit more throttle angle to open the gates to hell.
What is causing this part throttle behavior?
How can it be tamed?
Can spark plug or coil packs create such behavior?
I have a few VAGcom logs, not cleaned up yet.
I can take more; let me know what groups/parameters I should log),
Old Jan 12, 2013 | 06:12 AM
vtraudt's Avatar
Also noticed: larger value for throttle position is 86.4 degree.
Shouldn't that be 100%?
vtraudt
1.8T Discussion
Oct 4, 2012 05:58 PM
Distinct
Jul 23, 2006 01:30 PM
1.8mike
Jan 11, 2006 10:46 AM
scirocco78
Sep 2, 2005 07:21 AM
Avantgarde
9
Sep 1, 2005 11:38 AM
