cel... codes inside. please help diag
Old May 14, 2009 | 12:15 PM
SemiProQuattro's Avatar
Default cel... codes inside. please help diag
got a cel and wanted to know if anyone can lend a hand on where is should start with fixing these codes.... any help would be great
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 518 AK
Component: 1.8L R4/5VT G 0006
Coding: 0016711
Shop #: WSC 12596
8 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 002 - Lower Limit Exceeded - Intermittent
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 008 - Implausible Signal
17743 - Engine Torque Monitor 2: Control Limit Exceeded
P1335 - 008 - Implausible Signal - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal
16685 - Cylinder 1 Misfire Detected
P0301 - 008 - Implausible Signal
16687 - Cylinder 3 Misfire Detected
P0303 - 008 - Implausible Signal
16686 - Cylinder 2 Misfire Detected
P0302 - 008 - Implausible Signal
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04275
Shop #: WSC 06435
1 Fault Found:
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AD
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63351
No fault code found.
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 00003
Shop #: WSC 63351
Address 15 -------------------------------------------------------
Controller: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
Shop #: WSC 63351
2 Faults Found:
01217 - Side Airbag Igniter: Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent
00532 - Supply Voltage B+
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01041
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 950 P
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01231
Shop #: WSC 09108
WAULC68E74A247374 AUZ6Z0D0038079
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1512
Coding: 11788
Shop #: WSC 63351
Address 56 -------------------------------------------------------
Controller: 8E0 035 195 H
Component: symphony II PM6 0460
Coding: 00201
Shop #: WSC 00003
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
49-00 - No Communications
End -------------------------------------------------------
Old May 26, 2009 | 04:47 PM
spoiledA4's Avatar
New Member
Alright first thing I can think of is this. Get a new battery, or get yours checked. from there, clear all of your codes, this should allow you to see what comes back up. Then when they start coming up you can narrow it down. These pay just be pending DTCs that appeared which will happen if its not emmission related. Way to be Audi.
Old May 26, 2009 | 04:50 PM
spoiledA4's Avatar
New Member
another thing to do. Open up the select palet and then go to engine. open up measuring blocks and go MBs 14 and 15. This tells you all the misfire information that you should need. MB 4 will tell you voltage or should. All of these are for my b5 a4 1.8t but they should work. give them a try
Shaun
VAG-COM Discussion
Mar 27, 2008 05:27 AM
Kingttr
May 30, 2007 02:56 PM
BrokenRocket
Feb 2, 2006 01:48 PM
Bvarghese
Dec 25, 2005 07:37 PM
s4florida
Apr 10, 2005 08:04 AM
