Help!!!
Old Aug 24, 2005 | 05:44 AM
minibike4's Avatar
New Member
Default Help!!!
Hey im from Fort washington PA, and i own a 2001 audi a4 tiptronic 1.8t. I have the Ko4 installed with AWE GIAC software and the tip chip. I also have a front mount installed. I am having boost issues and just fixed a leak but now i feel that its running like crap again. When i hit it off the line it only spikes to about 10-12psi then as i move in gears it will increase up to 15-17psi then if i get lucky to 20psi or above. Now i know something is wrong here and i dont have the man power to look at it from the mechanic side. If so could you write back to me if you are in the area and could help out. i would appreciate it. Thanks Andrew
