Window
Old Dec 29, 2008 | 12:42 PM
ggspeed860's Avatar
New Member
Default Window
2005 A4 1.8t Passenger side window goes down with a grind and sometimes will change direction throughout the process. For-instance when its going up it will turn and go down a bit then stop. Window Regulator?
Old Jan 1, 2009 | 07:23 PM
ray's a4's Avatar
Default I have the same damn problem.......
I have the same exact problem on my 99 A4 B5. The issue is the regulator. My problem there is a cable going from the motor around a plastic wheel at the top of the regulator, the cable slipped off the wheel to the side and causes the window to get stuck, because the motor senses a problem so it rolls it back down. I tried to put the cable back on but the F***ing plastic wheel broke so now i have to replace the regulator. Hopefully thats what the problem is you would have to take the door panel off to determine.
Old Jan 2, 2009 | 02:31 PM
ggspeed860's Avatar
New Member
Default Re: I have the same damn problem.......
do you know how to take the door panel off the car?
Old Jan 3, 2009 | 10:30 AM
Whoismario's Avatar
Default I just replaced both of mine. 2-3hrs each. Not hard just time consuming
There is a full write up on how to do it, just search for it.
Old Jan 5, 2009 | 08:19 PM
ray's a4's Avatar
Default the door panel off the car
Go to resources then tech articles go down to interior then click on Rear Window Regulator Replacement (B6)
mike1305
A6 (C7 Platform) Discussion
Jun 13, 2016 06:02 AM
MKLW
Oct 31, 2011 01:39 PM
gamblerS4
Nov 5, 2008 12:00 AM
TTGram
Apr 2, 2005 08:24 AM
Philipp DJ
Apr 22, 2004 12:29 PM
