coolant temp problem
Old Jul 15, 2005 | 09:59 PM
raverhaze's Avatar
New Member
Default coolant temp problem
hey guys...seems as though i'm having a bit of a problem with my coolant
i just replaced my temp sensor and reservoir tank...i capped off the coolant...and now my coolant temp light comes on ALL the time..but the coolant temp is fine it doesn't overheat...
i checked my coolant the other day and it was extremely low...actually it was very very low...so i uncapped the reservoir tank...and all of a sudden the coolant started to rise back up again...but the light still comes on...i have no idea what could be causing this...
has someone here ever have a problem like this before...if so can you tell me how i can fix this...thanks
Old Jul 15, 2005 | 10:31 PM
moribundman's Avatar
Is the sensor in the bottom of the expansion tank plugged in?
Old Jul 16, 2005 | 04:56 AM
quattrorally's Avatar
Default Air in the system ???
have you tried bleeding the system ? there is a bleader valve near the top of firewall roughly in the middle of the car.
If that does not work I have seen people do this:
1)make sure the coolant is cool (engine off)
2)oprn the reservoir tank
3)turn on the engine and let it run for a while
as the engine runs and the coolant pump circulates the coolant some of the bubbles in the system escape throught the open reservoir tank.
Old Jul 17, 2005 | 07:47 PM
raverhaze's Avatar
New Member
Default response
yeah man...everything is as it should be...I'm almost positive that it could be air in the system...quattrorally isn't the first one that suggested it...i'm going to try and uncapping the tank and letting it sit for a while like he said...but if it's a no go then i guess i'll just get it bled at my local shop...thanks for the help you guys...
Old Jul 17, 2005 | 08:13 PM
Bleeding all air out can be difficult -- good luck!
dubblrest1985
Audi 100 / A6 (C4 Platform)
Dec 18, 2010 12:28 PM
jboku
Jun 24, 2008 12:15 PM
s eight
Oct 17, 2007 05:15 PM
dutchy2.0turbo
A4 (B7 Platform) Discussion
Feb 18, 2007 04:26 AM
bes4000
Jan 13, 2003 05:14 PM
