what kind of replacement spark plugs for 96 2.8q? just going for stock performance
Old 08-30-2003, 01:14 PM
New Member
Libtek13's Avatar
Old 08-30-2003, 01:19 PM
moribundman's Avatar
Default OEM plugs are the excellent tri-electrode NGK BKUR6ET-10
Get them from a VW dealer for about $7 per plug. An Audi dealer will charge more.
VW part number: 101 000 033 AA
<img src="http://pictureposter.audiworld.com/50038/ngk.jpg">
Old 08-30-2003, 01:28 PM
Junior Member
bogelo's Avatar
Default Beru silverstone
I broke 2 of my denso iridium when I wanted to set the gap and just realized that they are preset from the factory.
They are awesome spark plugs, but they are so expensive. I don't want just to replace 2 ($22) of them that are broken, thus I have to spend another $66 for the whole set.
So, I went to another route using beru silverstone. 2 reasons I change to beru silverstone: 1. they are cheaper 2. I want to try new things. They are also good, but not as good as denso iridium.
Actually spark plugs don't make much difference in your car performance. I also tried AC delco, and they are good too.
The difference in your spark plug is when you have upgrade (turbo, supercharger, nitrous). I have nitrous setup in my car and I noticed Denso iridium has less misfires than beru silverstone.
AC delco can't be used for nitrous, since they are "hot" plugs.
AC delco rapidfire 9 (U.S) $3.99/piece
beru silverstone (germany) $7/piece
Denso iridium (japan) $11/piece
hope this helps.
Old 08-30-2003, 01:48 PM
Default Have you tried Beru Ultra-X UFX5.6?
They are four-prong plugs that cover two heat ranges at the same time (5 and 6).
I'll try those next. Already got them.
The Beru part number is 0 002 345 601.
Old 08-30-2003, 02:11 PM
New Member
Libtek13's Avatar
I just bought some Bosch Platinum2's, you think those will do the job?
Old 08-30-2003, 02:28 PM
AudiWorld Expert
MikTip's Avatar
Default A/C Delco Rapid Fire #9's! ;O)
<center><img src="http://www.acdelco.com/images/pi_plugs_rap_prod2.jpg"></center><p><ul><li><a href="http://www.acdelco.com/html/pi_plugs_rap_closer.htm">http://www.acdelco.com/html/pi_plugs_rap_closer.htm</a</li></ul>
Old 08-30-2003, 02:35 PM
New Member
Libtek13's Avatar
any idea how much those run?
Old 08-30-2003, 05:55 PM
JWG
Member
JWG's Avatar
Best plugs I have put into my car--wonderful longevity and fewer misfires!
Old 08-30-2003, 08:30 PM
Default I can't wait to try them!
I'm running the NGKs right now, because I want to see if I'm back to normal looking plugs after that disaster with the Bosch +4 plats.
Old 08-30-2003, 09:11 PM
Junior Member
bogelo's Avatar
I never had any misfires before I use "GAS" =)
Quick Reply: what kind of replacement spark plugs for 96 2.8q? just going for stock performance
