Engine Codes.....
Old Apr 19, 2005 | 12:27 PM
mbando's Avatar
Default Engine Codes.....
I took the car to Advanced Auto Parts today to get the codes checked for free... and well this is what the code ticket reads:
Vehicle Scanned
Global OBDII
Vehicle
DTC (Codes)
P0401
EGR Flow Insufficient
DTC Pending (Codes)
No Faults Detected.
Can some one help me with what this means. The guy there said my exhaust gases were going back up into the engine area? how does that even happen? Anyway does anyone have any better ideas or how to fix it?
Old Apr 19, 2005 | 12:39 PM
moribundman's Avatar
Default Maybe the EGR passage is clogged!
Clean out the carbon and soot buildup in the passage.
The EGR valve goes rarely bad. It's an expensive part, so you don't want to replace it unless you absolutely have to to. Test it.
Old Apr 19, 2005 | 12:46 PM
mbando's Avatar
Default Is there a special way to clean it?
Do need a special solution or will water be fine?
Old Apr 19, 2005 | 12:48 PM
mbando's Avatar
Default I have the chilton book but there is no picture of what it looks like...
anyone have a picture or can they describe it?
Old Apr 19, 2005 | 12:58 PM
Default An electric drill with a piece of flexible wire with a frayed end will work
Shove the wire into the pasage and losen all the builduo. Then suck out the debris with a vacuum cleaner.
Good luck with removing the EGR valve. I tried once and gave up. That sucker is stuck for good!
Old Apr 19, 2005 | 01:16 PM
mbando's Avatar
I will give it a shot if I knew what it looked like...
Old Apr 19, 2005 | 02:17 PM
Default Check 12v.org
Bookmark the whole site.<ul><li><a href="http://www.12v.org/engine/index.php?section=cl&amp;view=rear">Look for EGR valve in the diagram</a></li></ul>
Old Apr 19, 2005 | 02:53 PM
mbando's Avatar
Default Thanks, that really helps a lot
Sounds good and I think tomorrow I will fix the clog and clean the throttle body at the same time, yeah.
Thanks for the help
 Michael S. Palmer
Old Apr 19, 2005 | 03:35 PM
Default This should help:
The search funticon reveals a bunch of useful posts. You may want to look around further.
An old speedometer cable works well for cleaning the EGR passage.
Check <a href="https://forums.audiworld.com/12v/msgs/1934.phtml"> this post</a> and the <a href="https://forums.audiworld.com/12v/msgs/1935.phtml"> reply</a> to it.
Old Apr 19, 2005 | 07:56 PM
Ghostfire's Avatar
Banned
Default I hate removing it : /
Mucho glasious &lt;---spelling glad I dont have to clean it every six months like the ISV.
