first gear vibrations when i let off the gas
Old Sep 9, 2007 | 01:03 PM
kalivornian's Avatar
Member
Default first gear vibrations when i let off the gas
when i'm in first gear and i slowly accelerate to around 3500 rpm's and then i let off the gas my car kinda jerks a bit , basically its not smooth.... why is this??? i'm approaching 200k miles... do i need a 'tune up' or ... what explain help please? ;D
Old Sep 9, 2007 | 04:12 PM
1995Qsport's Avatar
normal. at least for me.
Old Sep 9, 2007 | 05:40 PM
Member
Default really? crap.. i'm not really a fan of it, specially after dring my buddies '01 GTI VR6
blaaaaaa oh well
Old Sep 9, 2007 | 07:39 PM
EDIGREG's Avatar
Default Normal...that is drivetrain slack...
you can reduce it with stiffer tranny, engine, and snub mounts. It's probably especially bad for you due the 200k miles of wear on the mounts.
Old Sep 11, 2007 | 07:32 AM
sdb90's Avatar
Default I conccur wholheartedly!!!! replace your mounts....
I would guess mainly the two trannys and then get a poly snub mount from 034, and that should help with quite a bit of the problem....I am doing exactly this in the VERY near future. Regardless you are still gonna have some normal slack as do I and most of us.
Tranny mounts aren't expensive and a poly snub mount I think is like 20 bucks at www.034EFI.com
(i have heard good things of these mounts)
Old Sep 11, 2007 | 07:36 AM
sdb90's Avatar
on that not has anyone ever replaced subframe bushings with the billits from 034?
Old Sep 11, 2007 | 05:22 PM
Member
thanks for responses.....are they hard to swap? time? sorry for being lazy.. ill check faq!! ;D
Old Sep 11, 2007 | 06:33 PM
EDIGREG's Avatar
Tranny and snub mounts are very easy...engine mounts are a bit harder
Disher04
Nov 4, 2009 08:22 PM
Ondurass
Audi allroad
May 12, 2009 05:57 AM
DM-S4
19
Mar 15, 2006 06:44 AM
sk88erguy
Audi Original "S" Cars
16
Feb 23, 2006 05:59 AM
QuattroPwr
11
Dec 27, 2005 05:06 PM
