Mance here is the problem
Old Jan 14, 2005 | 07:39 PM
Rob K's Avatar
Default Mance here is the problem
Here is how far you will be off by when you flip the manifold. Looks like its off by about an inch.
<img src="http://pictureposter.audiworld.com/620/dsc02093.jpg">
The first point of interference is the rear mounts for the powersteering pump. I can't show it very well but even if you grind off the two mounts the bulge at the top of the block will still prevent the manifold from mounting by about 1/4"-1/2".
<img src="http://pictureposter.audiworld.com/620/dsc02094.jpg">
Old Jan 14, 2005 | 07:56 PM
VAP's Avatar
VAP
Default I'm hoping to grind the block down a bit and mill the IM bottom.....
I knew PS pump was going to be be scrapped in this effort all along so its fasteners are "outta there!. DAMN I hate it that I disassembled all my spare motors! Especially since I keep heads here and blocks at Champagne.
Given what you've got there is grinding/milling look feasible if the PS pump is totally disregarded?
PS; Thanks!
Old Jan 14, 2005 | 08:19 PM
Rob K's Avatar
Default I'll check it in the morning.
I've only given it a quick look but I will see if it is doable.
Old Jan 15, 2005 | 02:14 PM
The Devil's Avatar
Member
Default javad is using a mr2 electric power steering pump on his 5 cylinder motor.
<center><img src="http://www.80tq.com/images/20vt/80tq20vPics/DSCF0280.sized.jpg"></center><p>
I am converting my coupe to vacumn assist and may go down this road also.<ul><li><a href="http://www.80tq.com">http://www.80tq.com</a</li></ul>
AudiQua
Jul 14, 2015 08:00 AM
fire_warrior_3
May 13, 2012 10:13 AM
lrrr
Apr 19, 2006 10:56 AM
BoostedA4tQ
Jul 28, 2004 08:23 PM
DasTT
Feb 15, 2003 06:56 AM
