one quick question..
Old May 17, 2007 | 03:38 PM
1995Qsport's Avatar
Default one quick question..
i have a 3 pin MAF plug in and im buying a type-A MAF and don't know if it is a 4 or 3 pin. are all type-a maf sensors 3 pin or some 3 and some 4? sorry for consecutive posts. thanks
dustin
Old May 17, 2007 | 03:59 PM
1995Qsport's Avatar
Default Re: one quick question..
i went to snap some shots..
here is my plug in..
<img src="http://pictureposter.audiworld.com/119349/p1010149.jpg">
and here is bassicly my MAF
<img src="http://pictureposter.audiworld.com/119349/p1010146.jpg">
i don't know what do to im really confused on what i would have to do if the sensor for the MAF im buying is a 4-pin? how would i convert my plug-in to a 4-pin?
Old May 17, 2007 | 04:13 PM
nothing's Avatar
Default Read a LOT more before you do anything.
All the answers are here. Search. Nobody is responsible for blowing up your car but you - and at the rate you are going that will happen soon.
Old May 17, 2007 | 06:27 PM
1995Qsport's Avatar
Default Re: Read a LOT more before you do anything.
i actually did read alot, and alot about you. i know you did the 4 to 3 wire swap, but im still confused on what type-a MAF's persist of? do all of there sensors have the 4-pin connector because i plan on basically just swapping the sensor into my large bore housing. but if the connector on the sensor is 4 pin i wouldn't know what to do. i dont know why your doggin me soo much i know i don't know as much as you but im still learning and just need some advice so i don't blow up my car haha.. so just either give me a quick explanation to help me learn or don't read or reply to my posts.
Old May 17, 2007 | 06:35 PM
EDIGREG's Avatar
the type A MAF will be 3 pin, direct swap, dont worry.
Old May 17, 2007 | 06:46 PM
nothing's Avatar
Default You won't be able to swap just the sensor to your housing, the mounts are different.
You will need to use the whole MAF. Just cut out the middle sampling tube, do not mess with the bore of the MAF at all, and do not smooth out the ridge that runs around the middle of the MAF.
The correct size of o-ring is in the archives somewhere. I'm not comfortable repeating it again since someone else came up with it. It will keep you from getting too lean.
Even better would be paying the master to mod your MAF for you. It will come with an o-ring pre-installed, and will out-flow what you can do yourself by a wide margin.<ul><li><a href="http://vintageaudiperformance.com/">The Man.</a></li></ul>
Old May 17, 2007 | 07:13 PM
1995Qsport's Avatar
Default Re: You won't be able to swap just the sensor to your housing, the mounts are different.
thanks man that cleared up alot of things for me, the guy im buying it from already cut the sampling tube out and did a good job.. ive been looking into the correct o.d of o-rings and have found 9mm all the way to 11mm so ill have to try..but thanks for the help and thanks to edigreg you lifted a weight of my chest..thumbs up for both of you.
Old May 19, 2007 | 11:01 AM
dragon-ryder's Avatar
Default I'm pretty sure the mounting point locations on the Type-A maf are different then the non-a
the bolts are on opposite sides i believe. You'll need to use the Type A housing as well as the sensor.
 Pouria Savadkouei
 Michael S. Palmer
Old May 19, 2007 | 11:18 AM
nothing's Avatar
That's what I said right above the post you just replied to.
Old May 19, 2007 | 11:27 AM
Just woke up ), i'm not running on all cylinders yet and decided to get my AW fix, haha
